If both the brake lights and rear turn signals are not functioning in your 2008 Dodge Charger, there are several possible causes to consider. Here are some common issues that could lead to this problem:
1. Blown fuses: Check the fuse box for any blown fuses related to the brake lights and turn signals. A blown fuse can interrupt the circuit and prevent the lights from working. Refer to your vehicle's manual to locate the specific fuse for these functions and replace it if necessary.
2. Faulty bulbs: Inspect the bulbs in the brake lights and turn signals to see if they are burnt out or damaged. If a bulb is not working, it should be replaced. It's possible that multiple bulbs have failed simultaneously, leading to both the brake lights and turn signals not functioning.
3. Wiring issues: Check the wiring connections and harnesses for any signs of damage, loose connections, or corrosion. Faulty wiring can disrupt the electrical flow and prevent the lights from operating. Repair or replace any damaged wiring as needed.
4. Malfunctioning brake light switch: The brake light switch, located near the brake pedal, activates the brake lights when the pedal is pressed. If the switch is faulty or misaligned, it can cause the brake lights to not work. Consider having the brake light switch inspected and replaced if necessary.
5. Faulty turn signal relay: The turn signal relay controls the flashing of the turn signals. If the relay is defective, it can prevent the rear turn signals from operating. Consider replacing the turn signal relay if other potential causes have been ruled out.
If troubleshooting these common issues does not resolve the problem, it is recommended to consult a professional mechanic or authorized Dodge service center for a more accurate diagnosis and repair. They will have the expertise and necessary tools to pinpoint and fix the specific issue with your 2008 Dodge Charger's brake lights and rear turn signals.
eBayFind great deals on eBay for Dodge Charger 3rd Brake Light in Tail Lights. ... Will fit:2011 - 2013 dodge charger. ... I swapped this out for the third brake light W/ backup camera so I no longer need this one. Item is .... There are three wires; positive driving / strobe flashing blinker mode, positive backup / brake light mode and ...Missing: deck
Mar 15, 2009 - 12 posts - 3 authors
i would try and test if you even have power at the 3rd brake light. that way ... work, the circuit is working up to S348 splice where it splits to left/right/CHMSL. ... You'll have to undo the rubber boot to examine the wire. ... 2011 Dodge Charger R/T Plus AWD- Redline - 5.7L Hemi Registry #1650 Tbird100636
you need to inspect wire harness @ rear and along frame rail , corrosion , damaged wire, bad connection, check for continuity, power, ground wires are extremely important . brake light switch could be at fault !!!!!!!!, power to both brakes & turnsignals must be determined , both of these circuits cross each other, see wire diagram
It sounds like you may have a bad starter. If your starter is bad your car will not turn over, but everything else will still work like normal. I would start there first. I hope this helps.
My 07 dodge charger brake light,abs, esp, bas light on an check engine light on an the hand show u how fast u going don’t work I took it to auto zone an they run a check on it an the code showed up u1120 an u1121i replace the rear brake sensors an drove it around the corner but the lights are still on.
IT MAY BE BRAKE SWITCH UNDER DASH SOME TIME WIRE BRAKES THERE AND OR SWITCH IS BAD OR LOCK OUT SWITCH ON SHIFTER IS DOING THIS HOPE THIS HELP THAT IS BRAKE LIGHT SWITCH ON PEDLE UNDER DASH MAKE SURER YOU HAVE POWER THERE
Just because the bulbs look fine, doesn't mean they are. Start with the bulb replacement. If this doesn't solve it, and it has under 36K, it should still be under factory warranty. Shouldn't cost anywhere near $200 either way.
