Circuit/System Description
The sunroof control module supplies each of the sunroof switch signal circuits with a 12-volt reference. When a switch is pressed the signal circuit is pulled low signaling the sunroof open or close request. The module determines the motor direction based on inputs received from the sunroof switch.
Sunroof Motor/Actuator Initialization/Teach Process
Perform the initialization/teach procedure any time:
A new sunroof motor/actuator has been installed.
The existing sunroof motor/actuator has been removed and reinstalled.
The sunroof system has suffered 3 interruptions for emergency events, i.e. anti-pinch, debris in tracks etc., and normal operation is canceled.
By performing the initialization/teach procedure, the sunroof motor/actuator records the open vent stop position. The motor/actuator will then understand the other positions, closed and full open soft stop, and allow express and obstacle detection functions.
- Ensure that all electrical harness connectors are connected.
- Turn the ignition to ON.
- Completely close the sunroof window with the manual close switch.
- Press the sunroof vent switch to the vent open position until the sunroof window stops, and continue holding the switch for at least 10 seconds.
Important: The initialization/teach procedure is not complete if the battery and/or ignition power has been interrupted during the process.
The Initialization/Teach Process must be restarted if the procedure is not carried out completely.
- Verify the operation of the sunroof in all positions.
If this does nothing !
Important: Because of the accessibility of the sunroof switch, perform the sunroof switch component test before beginning the Circuit/System Testing.
Power Sunroof Malfunction
- Ignition OFF, disconnect the harness connector at the sunroof control module.
- Test for less than 5.0 ohm between the ground circuit terminal 2 and ground.
If greater than the specified range, test the ground circuit for an open/high resistance.
- Verify that a test lamp illuminates between the B+ circuit terminal 1 and ground.
If the test lamp does not illuminate, test the B+ circuit for a short to ground or an open/high resistance. If the circuit tests normal and the B+ circuit fuse is open, replace the fuse and replace the sunroof control module.
- Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 5 and ground.
If the test lamp does not illuminate, test the ignition circuit for an open/high resistance. If the circuit tests normal, refer to Retained Accessory Power (RAP) Malfunction.
- Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 6 and ground.
- Ignition OFF, connect the harness connector at the sunroof control module.
- Disconnect the harness connector at the sunroof switch.
- Test for less than 5.0 ohm between the ground circuit terminal 5 and ground.
Important: Apply ground to the module for no longer than 2 seconds at a time or the module could be damaged.
When performing the following tests, make sure that the sunroof or sunshade is not at its end of travel position by switching the grounded jumper to the other signal circuit if the sunroof or sunshade does not move in one direction.
- Ignition ON, momentarily install a 10-amp fused jumper wire between the signal circuit terminal 6 and ground. The sunroof should move.
If the sunroof does not move, test the signal circuit for a short to ground, short to voltage or an open/high resistance. If the circuit test is normal, replace the sunroof control module.
- Momentarily install a 10-amp fused jumper wire between the signal circuit terminal 4 and ground. The sunroof should move.
- With the sunroof in the fully closed position, momentarily install a 10-amp fused jumper wire between the signal circuit terminal 2 and ground. The sunroof should vent open.
If the sunroof does not vent open, test the signal circuit for a short to ground, short to voltage or an open/high resistance. If the circuit test is normal, replace the sunroof control module.
- Momentarily install a 10-amp fused jumper wire between the signal circuit terminal 8 and ground. The sunroof should close.
If the sunroof does not close, test the signal circuit for a short to ground, short to voltage or an open/high resistance. If the circuit test is normal, replace the sunroof control module.
- If all circuits test normal, test or replace the sunroof switch.
