20 Most Recent Sylvania SDVD1030 10-inch Portable DVD Player Refurbished Black Questions & Answers
tip
How to clean dirty battery terminals
Use regular soda.Soak one terminal at a time,you will see bubbles a sign that is getting cleaned,after a couple of minutes rinse wit h water and dry.To prevent this from happening again just rub a little bit of grease on the terminals
Sylvania SKCR2713 Undercabinet Music System with Bluetooth - Bluetooth not working.
Question moved to Sylvania category There are only Owner Manuals https://www.justanswer.com/recorders-and-players/fi5ji-sylvania-skcr2713-undermount-cabinet-am-fm-bluetooth-cd.html https://www.google.com/search?q=sylvania+skcr2713+wiring+diagram+pdf You could take it to an audio technician and have it diagnosed by components. There _may_ be an internal fuse. ..
12/1/2023 12:06:26 AM • Sylvania Audio... • Answered on Dec 01, 2023
Trying to find sylvania projection clock radio
I have one for sale. New in box. Never used.
9/24/2023 7:24:51 PM • Sylvania Audio... • Answered on Sep 24, 2023
Sylvania cd player #NB501SL9 want open
It is because the CD tray is stuck or is jammed. Try turning off the stereo. You might also try jiggling the trays really gently as 1 of them could be stuck here.
5/16/2023 7:42:34 AM • Sylvania Audio... • Answered on May 16, 2023
What kind of Headphones/ear buds for Sylvania SRCD243PL-ASST6
Any that will fit into the socket, as it's more of personal choice and to some extant how much you want to spend on the quality of the headphones. Many stores let you listen to the headphones or ear buds. Human hearing is not the same for everyone. So you need to listen to some before finding out the best for you. It might also depend on how comfortable they are to use. There's nothing worse than headphones that make you ears sweat!
9/8/2022 6:44:30 AM • Sylvania Audio... • Answered on Sep 08, 2022
No Bluetooth on Sylvania SKCR2713 Kitchen Clock FM radio with CD player & Bluetooth.
Has it worked before? Is it new? Did you read the manual, or just 'wing it'? Tip & How-To about Miscellaneous Pairing Bluetooth Devices Posters often ask "How do I pair my Bluetooth ???" Insert whatever device you have at the question marks. Generally, you need to read the instructions for the camera, headset, speakers or whatever the Bluetooth device is. Roughly speaking though. Settings - Bluetooth - Search, on the Android, iPhone, Windows phone whatever. With camera, speaker, headphones or whatever the Bluetooth device is, you have to press a button on that device to send out the signal. On my Bowers and Wilkins T6 Speakers, there is a button on the top with the Bluetooth symbol on it. This is the part people usually don't do and ask for advice, thinking it will do this automatically. When the Android device recognizes it, click Pair, and if it asks for a code, the Default is '0000', (four zeros, no quotes). Posted by ADMIN... on Nov 19, 2016
12/23/2021 3:27:02 AM • Sylvania Audio... • Answered on Dec 23, 2021
Where can I get a Sylvania sdvd7027 remote please?
Edited to correct spelling of 'Sylvania'. Moved to the correct category. The answer is here, 30 bucks. https://www.google.com/search?q=Sylvania+sdvd7027+replacement+remote ..
7/1/2021 6:29:43 PM • Sylvania Audio... • Answered on Jul 01, 2021
Sylvania SMP2012. Apparently fully charged. Why doesn't it turn on?
On Off switch is the slide button on the side The switch may be faulty. You don't normally need it switched on to use USB, as the computer is supplying the power. This says it needs to be on for charging, that is odd! Battery 3. Remarks (Additional information for Adaptor purchase) 2.1 Make sure the power switch is on to charge, or the player could not be charged properly. The LED light 2 and LED light 1 are on when the player is charging, the light 1 will be off when the battery is full 3.1 The adaptor must be conformed to following standard could not be charged properly. The LED light 2 and LED light 1 are on when the player is charging, the light 1 will be off when the battery is full 2.2 Disconnect the player and charger if you want to stop charging 3.1.2 Output: 5.2V 0.2V 3.1.3 Max.: 350mA 3.1.4 4 pins adaptor When connecting to the computer via USB, it WON'T be recognised as such, but it you open Windows File Explorer, you will see it as a Volume in the left hand side pane. Drag music to a folder and drop music in from there. http://portablemedia.manualsonline.com/manuals/mfg/osram_sylvania/smp2012.html ..
12/15/2020 1:00:00 AM • Sylvania Audio... • Answered on Dec 15, 2020
I do not know how
Hi crystal 1299...
Downloading Music to MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your data cord, besure Windows Media Player is on.
6...Windows Media Player should recognize the MP3 player and sync with it.
7...After it is synced with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Free Answer...Please take time to rate me
4/21/2020 8:32:49 AM • Sylvania Audio... • Answered on Apr 21, 2020
Sylvania stereo wireless speakers do i need the transmitter cause i dont have one
Well, what are you trying to use it on? Does your device have Bluetooth? If you have Bluetooth. All you have to do is go into settings on your device and turn on Bluetooth. Follow the instructions and it should work... Regards Geoff
1/6/2020 12:21:41 PM • Sylvania Audio... • Answered on Jan 06, 2020
Manuel for sylvania clock radio scr1206bpl
Hello Rita, I am sending you the link so you can download the user manual of your, Sylvania clock radio scr1206bpl I hope you find the information useful Greetings Franco Dosil Hola Rita, te envio el link para que puedas descargar el manual de usuario de tu ,Sylvania clock radio scr1206bpl Espero te sea util la informacion Saludos Franco Dosil https://data2.manualslib.com/pdf4/95/9449/944856-sylvania/scr1206bpl.pdf?19d9acb7260bfa8d2564b71d52fa0231&take=binary
5/4/2019 5:21:04 AM • Sylvania Audio... • Answered on May 04, 2019
Sylvania clock radio SCR1206B why the digital clock is so fast and advance
Sounds normal. Most digital clocks have a rapid set in forward and a slow in backwards. Helps you to get through the hours quickly. As you speed past the correct setting, you then backup slowly to the correct time.
4/29/2019 8:55:12 PM • Sylvania Audio... • Answered on Apr 29, 2019
I have sylvania scr124t clock radio. Is there a manual for it? I don't want the alarm to go off.
A lot of manuals can be accessed by googling them. Now hurry up before the alarm goes off!
11/8/2018 12:02:35 AM • Sylvania Audio... • Answered on Nov 08, 2018
Sylvania SDVD1030 10-inch Portable DVD Player Refurbished Black Logo
2 questions posted
Top Sylvania Audio Players & Recorders Experts
Aron
 Grubhead
Grubhead
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Audio Players & Recorders
Most Popular Question
kind headphones ear buds sylvania
  • Audio Players & Recorders
