20 Most Recent Franklin Industries FBC36OD Beverage Cooler Questions & Answers
0answers
MY EVERSTAR APPLIANCE BEVERAGE COOLER
Not worth fixing!
4/27/2017 11:10:09 AM • Franklin... • Answered on Apr 27, 2017
0answers
0answers
0answers
0answers
I have a wine chiller
There are many different causes behind machine not cooling. 1. Defrost can be the cause for your refrigerator notcooling problem. To check to see if you have a defrost problem, look in thefreezer to see if there is ice build up on the evaporator cover. (Theevaporator covers are either in the back of the freezer or on the bottom of thefreezer). 2. If the condenser fan (the one under refrigerator) is notworking, the compressor will cut off on the overload. If the evaporator fan isnot running, there will be no airflow to the machine. First walk up to therefrigerator and listen to see if the fans (one in the freezer on one under thebottom) are running. If one is running and the other is not then get to the onethat is not running and see if something is blocking it. If there is nothingblocking it then replace it. 3. Dirty condenser can be the cause for your refrigeratornot cooling problem. If the condenser is dirty, the compressor will cut off onthe overload. If theseparts working correctly, then probably the compressor itself is faulty. You needto replace it. Hope this will help you. Good Luck.
8/25/2011 12:31:42 PM • Franklin... • Answered on Aug 25, 2011
0answers
I am looking for a
Part number is: 1858900500
I called a distributor and they said they're no longer in business so that's probably why it was a bit harder to track down.
Cheapest one I found online was from Parts Wizard here.
Hope this info gets you back in gear ;)
3/11/2011 5:42:48 PM • Franklin... • Answered on Mar 11, 2011
0answers
0answers
Franklin Industries FBC36OD Beverage Cooler Logo
4 questions posted
Top Franklin Industries Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Franklin Industries Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Franklin Industries Refrigerators
Most Popular Question
hdbc36id wont get cold
  • Refrigerators
