20 Most Recent
Panasonic CS-S9NKUA Ductless Mini Split Wal Cool Air Conditioner Questions & Answers
Panasonic mini split air conditioner css9nkua error code h99 what does it mean
12.11 Freeze Prevention Control 2
• Control start conditions
o During Cooling operation and soft dry operation ? During thermo OFF condition, indoor intake temperature is less than 50°F or ? Compressor stops for freeze prevention control
o Either one of the conditions above occurs 5 times in 60 minutes.
• Control contents
o Operation stops
o Timer LED blinks and "H99" indicated
You may need the assistance of a technician. Service manual located here:
http://www.mcaair.com/docs/panasonicac/CS9NKUA%20CS12NKUA%20Service%20Manual.pdf
4/29/2015 5:07:56 PM •
Panasonic...
Answered
on Apr 29, 2015
Panasonic inverter air conditioner error code h11 pls help
Assuming you have a mini split and not a VRF system (although it is possible the error codes are the same),the h11 code typically indicates a communications problem between the indoor and outdoor units. This could be due to loose or broken wiring, a bad connection at either end or possibly a bad communications board in either the indoor or outdoor unit.
10/11/2021 7:39:18 AM •
Panasonic...
Answered
on Oct 11, 2021
What is error code h55 in panasonic floor mounted ac E28NFQ?
H55 error comes from the window that has not properly function to open, you must have off the breaker of the unit then, remove the upper window and check if the motor is not parallel to each both side, then return it and switch the breaker and turn on the unit
9/23/2019 2:44:00 AM •
Panasonic...
Answered
on Sep 23, 2019
How to reset timer flashing CS-PC12MKH
That's indicating that an error has been detected and you need to put the remote into service mode to find out what the error code is. You will have to repair the fault before it will return to normal operation.
5/22/2019 11:38:41 PM •
Panasonic...
Answered
on May 22, 2019
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display
Abnormality / Protection control
Abnormality
Judgement
Emergency operation
Primary location to verify
H00
No abnormality detected
Normal operation
H11
Indoor / Outdoor abnormal communica
tion
> 1 min after starting
operation
Indoor fan operation
only
• Internal / external cable connections
• Indoor / Outdoor PCB
H14
Indoor intake air temperature sensor
abnormality
Continue for 5 sec.
• Intake air temperature sensor (detec
tive or disconnected)
H15
Outdoor compressor temperature sensor
abnormality
Continue for 5 sec.
• Compressor temperature sensor
(detective or disconnected)
H16
Outdoor Current Transformer open cir
cuit
• Outdoor PCB
• IPM (Power transistor) module
H19
Indoor fan motor mechanism locked
7 times occurance
continuously
• Indoor PCB
• Fan motor
H23
Indoor heat exchanger temperature sen
sor abnormality
Continue for 5 sec.
O
(Cooling only)
• Heat exchanger temperature sensor
H24
sor 2 abnormality
Continue for 5 sec.
H27
Outdoor intake air temperature sensor
abnormality
Continue for 5 sec.
O
• Outdoor temperature sensor (detec
H28
Outdoor heat exchanger temperature
sensor abnormality
Continue for 5 sec.
O
• Outdoor heat exchanger temperature
sensor (detective or disconnected)
H30
Outdoor discharge air temperature sen
sor abnormality
Continue for 5 sec.
H33
Indoor / Outdoor wrong connection
• Indoor / Outdoor supply voltage
H38
Indoor / Outdoor mismatch (brand code)
H50
Ventilation motor abnormality
7 times occurance
continuously
• Indoor PCB
• Ventilation motor
H51
Nozzle lock abnormality
2 times occurance
continuously
• Nozzle
H52
Limit switch abnormality
• Indoor PCB
H97
Outdoor fan motor mechanism locked
2 times occurance
within 30 minutes
• Indoor PCB
• Fan motor
H98
Indoor high pressure protection
• Air filter dirty
• Air circulation short circuit
H99
Indoor heat exchanger anti-freezing pro
tection
• Insufficient refrigerant
• Air filter dirty
F11
Cooling / Heating cycle changeover
abnormality
4 times occurance
within 30 minutes
• 4-way valve
• V-coil
F90
PFC control
4 times occurance
within 10 minutes
• Voltage at PFC
F91
Refrigerantion cycle abnormality
2 times occurance
within 20 minutes
• No refrigerant
(3-way valve is closed)
F93
Compressor rotation failure
4 times occurance
within 20 minutes
• Compressor
F95
Cool high pressure protection
4 times occurance
within 20 minutes
• Outdoor refrigerant circuit
F96
IPM (power transistor) overheating pro
tection
4 times occurance
within 30 minutes
• Excess refrigerant
• Improper heat radiation
F97
Outdoor compressor overheating protec
tion
4 times occurance
within 10 minutes
• Compressor
F98
Total running current protection
3 times occurance
within 20 minutes
F99
Outdoor Direct Current (DC) peak detec
tion
7 times occurance
continuously
• Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
5/20/2019 7:44:36 AM •
Panasonic...
Answered
on May 20, 2019
Air swing not moving
This one is swing regulator
I need help
Its available or not
And whats the prince
5/14/2019 12:33:07 PM •
Panasonic...
Answered
on May 14, 2019
