20 Most Recent Bloomfield 1088 Coffee Maker Questions & Answers
Bloomfield Coffee Maker not brewing
Remove top panel and check the electrical wires for damage.
5/6/2010 4:07:05 PM • Bloomfield 1088... • Answered on May 06, 2010
Coffee is way to strong!!!
On the controller board, there is a solonoid time dial. turn this clockwise to increase time, counter- clockwise to reduce time.
Be careful to turn only a little at a time,vthough, and run a test brew to see how high it gets in the server, then re-adjust.
2/10/2009 5:49:37 PM • Bloomfield 1088... • Answered on Feb 10, 2009
Lights flashing
If your brewer is only flashing only after it heats up, your temperature might be set too high. Try turning it down, and if this doesn't cure it, your limit thermostat might be blown.
2/10/2009 5:42:37 PM • Bloomfield 1088... • Answered on Feb 10, 2009
Bloomfield pour over Model 8543...Taking very longto brew....How long should it take?
Call for service! Repairs should be performed by a qualified Bloomfield tech. *** the following is for information only *** * Your brewer has a tank that should have 1-1/2 pots of pre-heated ready to brew water. Pouring in a cold pot of water will push out the heated water into the funnel and over the coffee grounds then into the decanter. This should all start within 15 seconds of pouring water in machine (the top opening) and continue to brew for about 2 mins with a drip out for another minute. If your getting cold or luke warm water out of the brewer then you didn't give it enough time to pre-heat (about 20 mins.) Still not hot? Then call your vendor for service. * If brewer was not pre-filled prior to powering up then the Thermal fuse may have blown due to no water in tank and/or over heating. * Depending if the tank was empty and how hot the element got will determine what blows. * If it was completely dry when plugged in then the element got cherry red hot and may have melted gaskets as well as all the fuses. * Depending on the model, there may be 2 thermal fuses or even a 3d on the thermal blanket. * If the brewer was filled but left on for a long period (weeks?) then the tank just boiled off till the fuse blew. Good chance the element is ok. But have to check to be sure. * Pre-Heated tanks like this unit.usually have a normal load on from the warmer blanket. The load (amps) will kick up on the initial heating of the tank (filled with water) then drop down after reaching temperature. * There is an additional load if any warmers are turned on. * Some brewers have a separate heater switch (some call it a 'Vacation') on/off switch on a brewer will activate the main heater element. Some have a separate switch for the brew warming plate (Blanket stays on all the time) * Easiest way to check is amperage loads on each section. Continuity is a bit harder as it does not tell you if it's shorted (unless you know the resistance loads to begin with) * Final: Get a qualified service tech to check just to be safe. Aloha, ukeboy57
2/5/2018 5:36:47 AM • Bloomfield... • Answered on Feb 05, 2018
0answers
Won't brew
If you don't hear a "click" it is one of two or three things. First it could be the start switch. Second could be the solenoid coil or valve is stuck. Third the water line could be shut off or blocked up. Be sure to see that water is coming out of the water line before hooking it to the brewer. That means shutting down the valve, removing the line from the brewer, getting a pitcher to catch the water, have someone slowly turn on the water valve to see if water is flowing, and if not check the valve to see that it isn't crusted up or in need of a plumber. If you have water to the machine, the filter and solenoid are usually built together on the Bloomfield. Remember no "click" is probably an electrical malfunction...not always...but 95 percent of the time either the start switch or the inlet coil to the valve is bad.
9/4/2016 7:48:00 PM • Bloomfield... • Answered on Sep 04, 2016
Coffee maker overflows
Who owns the brewer. Usually the OCS supply does the maintenance. Office Coffee Systems sell and service the brewers...the service if for free. Does it have a label on the side or anywhere. If it is overflowing, is it out of the brew basket in to the pot?...There are a couple reasons for that. Is it a water line model?. If it is a pour over, it is human error. If it is a water line model it is probably a leaky inlet water valve. http://www.pamasco.com/bloomfieldsolenoidvalvesandrelatedparts.aspx
9/4/2016 7:37:51 PM • Bloomfield... • Answered on Sep 04, 2016
1920 articles of leslie h green from turtlelake mi bloomfield mi.
I found Leslie H. Green in two articles! click the links below and Type her name in the search bars. Good Luck! She sounds very interesting!
2/5/2016 10:39:13 AM • Bloomfield... • Answered on Feb 05, 2016
Drain the water from a bloomfield 9012 coffee maker
There is usually a pipe inside the machine. Depending on your machines configuration it may be in a side panel. Isolate the power and water. If you remove the tall front panel you should see inside a log silicone hose with a bung in the end. This is the drain tube. Pull it out from the machine, remove the bung and loosen the pipe clamp if fitted.
11/25/2014 10:02:41 PM • Bloomfield... • Answered on Nov 25, 2014
Flashing light code
what model bloomfield?
7/21/2014 9:49:54 PM • Bloomfield... • Answered on Jul 21, 2014
0answers
Schaerer SCP is not rinsing correctly
Check the Operating Temperature: Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding. Check for Ongoing Programs: If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee. Inspect the Brewing Unit: Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position. If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly. Inspect the Coffee Spout and Drainage Area: Check the coffee spout for any clogs or blockages. Clean it if necessary. Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage. Refer to the Operating Manual: Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
4/20/2024 9:02:57 PM • Coffee Makers &... • Answered on Apr 20, 2024
Dolce Gusto Coffee Machine. The cold water is working, but nothing coming out of the hot side. No sound, no water, but the cold works fine.
They make a thousand models. It sounds like the heating element has failed. Generic help and videos in the link but these machines need dealer service at regular intervals depending on the complexity of the particular model. https://www.google.com/search?q=Dolce+Gusto+coffee+Machine+no+hot+water ..
4/17/2024 5:11:02 PM • Coffee Makers &... • Answered on Apr 17, 2024
Question about the De Longhi Magnifica coffee machine.
These machines need dealer servicing every 6 to 12 months. They don't tell you that when you buy them. There are some ideas here https://www.google.com/search?q=De+Longhi+Magnifica+warning+triangle ..
4/16/2024 2:41:15 AM • Coffee Makers &... • Answered on Apr 16, 2024
SCHAERER VERISMO 701 AMBIANTE 15 ESPRESSO MACHINE. We have to reset the Verismo 701 continuously even when we have the beans container filled up to the top.
Question edited for clarity. These machine need dealer servicing every 6 to 9 months depending on usage. They don't tell you this when you buy them, but I have been fighting these types of machines for the 9 years before I retired. One place had 2 machines and another has 6. Once machine did 1,200 cups a days and was serviced every month. Airport Business Class Lounges. ..
4/12/2024 5:42:30 AM • Coffee Makers &... • Answered on Apr 12, 2024
2answers
Where can I find Cecilware 3K-GB-LD Cappuccino machine Error Codes, I'm getting ERR 1 on my machine
To find Cecilware 3K-GB-LD Cappuccino machine error codes like "ERR 1," refer to the machine's user manual or technical documentation. Alternatively, contact Cecilware customer support for assistance in diagnosing and resolving the specific error code on your machine.
4/6/2024 8:13:43 PM • Coffee Makers &... • Answered on Apr 06, 2024
Capresso "Perk" Percolator Coffee Maker, 12 Cup. I have 2 percolator model 405.05 and the cord burned out on both i would like to replace the cords
Question edited for a lot more clarity. This is a very standard appliance plug that you can get from Walmart, Home Depot any small appliance store or even Amazon https://ecscoffee.com/products/capresso-12-cup-perculator-405-05 They look to be here https://www.google.com/search?q=percolator+model+405.05+replacement+cord ..
4/3/2024 6:29:51 PM • Coffee Makers &... • Answered on Apr 03, 2024
Bloomfield 1088 Coffee Maker Logo
3 questions posted
Top Bloomfield Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Bloomfield Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Bloomfield Coffee Makers & Espresso...
  • Bloomfield Coffee Makers & Espresso...
Most Popular Question
bloomfield coffee maker not brewing
  • Coffee Makers & Espresso Machines
