20 Most Recent Sylvania LD320SS2 32-Inch 720p TV Combo Questions & Answers
Sylvania SKCR2713 Undercabinet Music System with Bluetooth - Bluetooth not working.
Question moved to Sylvania category There are only Owner Manuals https://www.justanswer.com/recorders-and-players/fi5ji-sylvania-skcr2713-undermount-cabinet-am-fm-bluetooth-cd.html https://www.google.com/search?q=sylvania+skcr2713+wiring+diagram+pdf You could take it to an audio technician and have it diagnosed by components. There _may_ be an internal fuse. ..
12/1/2023 12:06:26 AM • Sylvania Audio... • Answered on Dec 01, 2023
Trying to find sylvania projection clock radio
I have one for sale. New in box. Never used.
9/24/2023 7:24:51 PM • Sylvania Audio... • Answered on Sep 24, 2023
Sylvania cd player #NB501SL9 want open
It is because the CD tray is stuck or is jammed. Try turning off the stereo. You might also try jiggling the trays really gently as 1 of them could be stuck here.
5/16/2023 7:42:34 AM • Sylvania Audio... • Answered on May 16, 2023
What kind of Headphones/ear buds for Sylvania SRCD243PL-ASST6
Any that will fit into the socket, as it's more of personal choice and to some extant how much you want to spend on the quality of the headphones. Many stores let you listen to the headphones or ear buds. Human hearing is not the same for everyone. So you need to listen to some before finding out the best for you. It might also depend on how comfortable they are to use. There's nothing worse than headphones that make you ears sweat!
9/8/2022 6:44:30 AM • Sylvania Audio... • Answered on Sep 08, 2022
No Bluetooth on Sylvania SKCR2713 Kitchen Clock FM radio with CD player & Bluetooth.
Has it worked before? Is it new? Did you read the manual, or just 'wing it'? Tip & How-To about Miscellaneous Pairing Bluetooth Devices Posters often ask "How do I pair my Bluetooth ???" Insert whatever device you have at the question marks. Generally, you need to read the instructions for the camera, headset, speakers or whatever the Bluetooth device is. Roughly speaking though. Settings - Bluetooth - Search, on the Android, iPhone, Windows phone whatever. With camera, speaker, headphones or whatever the Bluetooth device is, you have to press a button on that device to send out the signal. On my Bowers and Wilkins T6 Speakers, there is a button on the top with the Bluetooth symbol on it. This is the part people usually don't do and ask for advice, thinking it will do this automatically. When the Android device recognizes it, click Pair, and if it asks for a code, the Default is '0000', (four zeros, no quotes). Posted by ADMIN... on Nov 19, 2016
12/23/2021 3:27:02 AM • Sylvania Audio... • Answered on Dec 23, 2021
Where can I get a Sylvania sdvd7027 remote please?
Edited to correct spelling of 'Sylvania'. Moved to the correct category. The answer is here, 30 bucks. https://www.google.com/search?q=Sylvania+sdvd7027+replacement+remote ..
7/1/2021 6:29:43 PM • Sylvania Audio... • Answered on Jul 01, 2021
Sylvania SMP2012. Apparently fully charged. Why doesn't it turn on?
On Off switch is the slide button on the side The switch may be faulty. You don't normally need it switched on to use USB, as the computer is supplying the power. This says it needs to be on for charging, that is odd! Battery 3. Remarks (Additional information for Adaptor purchase) 2.1 Make sure the power switch is on to charge, or the player could not be charged properly. The LED light 2 and LED light 1 are on when the player is charging, the light 1 will be off when the battery is full 3.1 The adaptor must be conformed to following standard could not be charged properly. The LED light 2 and LED light 1 are on when the player is charging, the light 1 will be off when the battery is full 2.2 Disconnect the player and charger if you want to stop charging 3.1.2 Output: 5.2V 0.2V 3.1.3 Max.: 350mA 3.1.4 4 pins adaptor When connecting to the computer via USB, it WON'T be recognised as such, but it you open Windows File Explorer, you will see it as a Volume in the left hand side pane. Drag music to a folder and drop music in from there. http://portablemedia.manualsonline.com/manuals/mfg/osram_sylvania/smp2012.html ..
12/15/2020 1:00:00 AM • Sylvania Audio... • Answered on Dec 15, 2020
I do not know how
Hi crystal 1299...
Downloading Music to MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your data cord, besure Windows Media Player is on.
6...Windows Media Player should recognize the MP3 player and sync with it.
7...After it is synced with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Free Answer...Please take time to rate me
4/21/2020 8:32:49 AM • Sylvania Audio... • Answered on Apr 21, 2020
Sylvania stereo wireless speakers do i need the transmitter cause i dont have one
Well, what are you trying to use it on? Does your device have Bluetooth? If you have Bluetooth. All you have to do is go into settings on your device and turn on Bluetooth. Follow the instructions and it should work... Regards Geoff
1/6/2020 12:21:41 PM • Sylvania Audio... • Answered on Jan 06, 2020
Manuel for sylvania clock radio scr1206bpl
Hello Rita, I am sending you the link so you can download the user manual of your, Sylvania clock radio scr1206bpl I hope you find the information useful Greetings Franco Dosil Hola Rita, te envio el link para que puedas descargar el manual de usuario de tu ,Sylvania clock radio scr1206bpl Espero te sea util la informacion Saludos Franco Dosil https://data2.manualslib.com/pdf4/95/9449/944856-sylvania/scr1206bpl.pdf?19d9acb7260bfa8d2564b71d52fa0231&take=binary
5/4/2019 5:21:04 AM • Sylvania Audio... • Answered on May 04, 2019
Sylvania clock radio SCR1206B why the digital clock is so fast and advance
Sounds normal. Most digital clocks have a rapid set in forward and a slow in backwards. Helps you to get through the hours quickly. As you speed past the correct setting, you then backup slowly to the correct time.
4/29/2019 8:55:12 PM • Sylvania Audio... • Answered on Apr 29, 2019
I have sylvania scr124t clock radio. Is there a manual for it? I don't want the alarm to go off.
A lot of manuals can be accessed by googling them. Now hurry up before the alarm goes off!
11/8/2018 12:02:35 AM • Sylvania Audio... • Answered on Nov 08, 2018
2answers
Ok the manual didn't tell me much I just need to find out how to work the CD player on a sylvania scr4986. Can someone help me. I'd really appreciate it.
Basic CD Operation: 1. Power the unit ON if STANDBY mode by pressing the STANDBY ON/OFF(#3).The default mode is RADIO,so press the FUNCTION button(#8) to switch to the CD mode. 2. Open the CD door by pressing the OPEN/CLOSE door release button(#9).Inset a CD with the label facing upwards and close the door. 3. The unit will read the disc and display the total number of tracks found on the disc on the display 4. To begin playback press the PLAY/PAUSE/BAND button(#1).The first brack on the disc will play. 5. To pause playback press the PLAY/PAUSE/BAND button(#1) once more.Pressing again resumes playback. 6. Press the STOP button(#2) to stop playback. 7. Use the AL 1/VOL- or AL 2/VOL+ buttons(13,14) to adjust the volume level. Advanced CD operation 1. Press the FWD/TUN+ button to skip to the next track.Press and hold to fast forward the current track.Release the button to resume normal playback. 2. Press the REV/TUN- button to skip to the previous track.Press and hold to fast rewind the current track.Release the button to resume normal playback. Random playback 1. Press and hold the SLEEP/RDM button(#15) either during playback or in STOP mode for 2 seconds and then release.You will see the letters RDM appear on the display to indicate the RANDOM mode in active. 2. If you enable the RANDOM function in STOP mode,press the PLAY/PAUSE/BAND button to begin playback.If you enable the function during playback the next track will begin the random order 3. To cancel the RANDOM playback mode,press and hold the SLEEP/RDM button(#15) for 2 seconds and release again.The letters RDM will disappear from the display to indicate the function has been cancelled. Repeat function 1. Before or during playback press the REPEAT/PROG button(#6) to repeat a single track indefinitely.You will see REP appear on the display when active. 2. To repeat all tracks on the disc,press the REPEAT/PROG button(#6) twice(or once more if you have already activated the repeat once function).You will see REP on the display blinking to indicate the repeat ALL function is active 3. To cancel any repeat modes,press the REPEAT/PROG button(#6) once more(if in repeat all mode or twice if in repeat once mode).The letters REP will disappear from the display. CD program playback. NOTE:You can only program a playback sequence while the disc is in STOP mode. 1. Press and hold the REPEAT/PROG button(#6).You will see P01 appear on the display to indicate the program function has been initiated. 2. Use the FWD/TUN+&REV/TUN- buttons to select the track you want to play in slot No 1. 3. Press the REPEAT/PROG(#6) to store the selected track in slot 1.The display will now display P02 to indicate your selecting the track for slot 2. 4. Repeat steps 2 to 3 for every track you wish to program up to a maximum of 20 tracks. If you try to program more than 20 tracks the display will revert back to P01 and will overwrite the first slot again. 5. Press the PLAY/PAUSE/BAND button(#1) to begin the programmed sequence playback. 6. Should you wish to cancel the programming you can press the STOP button to resume normal function.
10/8/2018 5:23:35 PM • Sylvania Audio... • Answered on Oct 08, 2018
Sylvania LD320SS2 32-Inch 720p TV Combo Logo
4 questions posted
Top Sylvania Audio Players & Recorders Experts
Aron
 Grubhead
Grubhead
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Audio Players & Recorders
Most Popular Question
kind headphones ear buds sylvania
  • Audio Players & Recorders
