20 Most Recent
GRACO INC LineLazer IV 200 HS Airless Line Striper - 1 Gun Questions & Answers
My graco linelaser 3900 IV pulsates/winks
Hi Brendan,
Your LineLazer is probably single stroking. This means that one of the 2 valves is not closing properly so that the pump is only working on the down or the up stroke. You need to switch off, depressure and open up the pump lower by knocking the lugs on the conical housing. Be careful not to lose any parts and note their order. clean out the inlet velve parts where the problem is usually found. With the inlet valve housing removed check the outlet valve in the end of the piston; use a small screwdriver and a torch; you will have lie on your back to do this. Call Lion Industries on 01543 251 560 if you still have a problem.
David Dundas
1/20/2014 12:33:17 PM •
GRACO INC...
Answered
on Jan 20, 2014
I need a head valve seat for central pneumatic 21 degree angle framing nailer model 60828 also need headvalve seat for 34 degree angle finish nailer 68020
I have not been able to purchase replacement parts for these nail guns , however, have repaired them using parts from Bostitch framers and or just make the part. If the seal fits over the top of the cylinder, then try using seal from Bostitch framer part #N70155 fits a bit tight but works. Heat with a hair dryer to soften and install. If the seat is incorporated within the head valve, just dig it out and replace it with liquid two part urethane. Just mix and pour it in. After cleaning out the old seal, place head valve on level surface and pour in the mixed urethane till slightly over full to give the seal a nice crown. The finish nailer might also be repaired using other brand of seals. Remove the old part and take it to service center for a possible match. Good luck with your repair.
What oil should I use in Handiair H8/25 Compressor?
Many air compressors use a mineral blend or a synthetic oil, such as synthetic hydrocarbon, polyol ester or polyglycol. It is important to use a lubricant specifically rated for air compressors; do not use a general-purpose motor oil used for automotive or other purposes.
Read your user manual for more information.
