20 Most Recent
HP Compaq Evo n620c Notebook Questions & Answers
I have wndows xp professional
You could have a nearly flat BIOS battery.
I recommend you replace the BIOS battery and configure the BIOS date and time etc.
Hi my compaq presario v2000
Hi!
Try restarting and on the manufacturers screen start tapping f8. You will then go to the advanced options menu. Choose safe mode. if you are able to go into safe mode without errors then do a system restore and restore it to an earlier date before you had this issue. If in safe mode and you are still getting this kind of issue then it would be best to reinstall the whole operating system but make sure to have your documents and other important data backed up.
Hello Im new here so please forgive me if i sound
As far as the computer world is concerned we are all unknowledgeable to some degree - but you described the problem accurately and gave correct information that is the first step to get help. I am unable to suggest a solution but maybe you can post your problem on this hp help forum or seek a solution already there.
http://h30499.www3.hp.com/t5/Notebook-HP-ProBook-Compaq-Slate/bd-p/bsc-274
If this computer has a CD (for XP) or DVD (for Vista and Win 7) and you have the installation disc you can
try a system repair by starting to re-install, and when asked press R for
repair (not install- that may delete your data). For that better study
more about the correct steps for your system and operating system.
Mic not work
Please try reinstalling the drivers. if it doesn't works like this then this must be your hardware problem... which can be a mic there fore you can use any exterior mic in place..
My compaq evo nc620c laptop wont boot up, only
Without having seen it, it sounds like a hard drive problem. Could be dead, could be the boot info has been destroyed (virus?).
ROM setup should be able to tell you more about the hard drive, and whether Setup can see it.
Where can I get detailed
If you are facing an issue of Dark Screen there are basically two reasons for that, either it's the Inverter or the Back-light.Make sure you are looking for the right and as recommended Inverter is where you should look first.
Now,it's better to get an Idea with the picture than to just read in the manual and waste time in figuring out which is what.To get an Idea of how to dismantle the Laptop and look for and change the backlight is this link
Backlight ReplacementLast but not the least...don't forget to check a lot of videos at youtube...see if you can find one of yours.
You tube VideosGood Luck.
I don't have the directions in my book for the
Here is a link to the online documentation. It is a 37 page color manual split into 8 files. The directions state that you should have a color printer handy.
http://www.knex.com/Thrill_Rides/DoubleDare_bonus.php
Hope this helps..
James
I have trouble of my desplay, power work ok but can not display any thing
hey. there is a inverter in LCD that makes view brightly shinely so you can see everything on LCD. anyway. if the inverter breaks down you get black screen. even inverter is working you get blanc screen you need to check LCD DATA CABLE that it not possible to reach it for you. i advise you to get the Service if you have warranty
have a good day.
pls rate this.
