20 Most Recent
Telex WT-55 Belt Pack Transmitter (027) 71062027 Microphone Questions & Answers
I belong to a local
Telex is an Electrovoice product, based in Minneapolis MN. Check their website for customer service, and a phone number. They are always happy to help.
If the product is older and has no replacement from the manufacturer, you may need to search online for auction sites that may sell older systems.
God Luck.
Alkaline batteries leak
Remove the batteries and wash it in vinegar (A mild acid to kill the alkali used in manufacture of the batteries)
Telex HT-100 with TE-10 head pulled off
I realize that this question was asked in December of 2011, but I just now found this question on this website today.Here's a picture that I took of the Telex HT-100 wireless microphone transmitter that I have showing the wiring on the circuit board.The green wire gets soldered to the lead of the 10 Megohm resistor that you can see in the picture.
I do not have a
Visit a local music retailer to purchase a cord. The same places that sell drums and electric guitars will have microphone cables.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
