20 Most Recent
Stanton C501 Dual DJ MP3 CD Player Questions & Answers
Skipping and Jumping
try CLEANING THE LASER FOCAL LENS with a cotton bus and windex. use a dry fresh one to remove any film after cleaning. IF problem persists, run machine on its end when mistracking occurs(may be hard if yo doing a gig). If the mistracking stops(because the top bearing in the motor is worn) then it may require a new spindle motor. A double check for worn bearings is a drop of 3 in 1 oil to the top bearing of the motor. If the mistracking stops, REPLACE MOTOR. Oiling it is just a short term solution and it will fail again.
If its not the spindle motor, you may need to REPLACE LASER ASSEMBLY I would do both for a commercial unit that does gigs. Where possible i also check the price of a COMPLETE NEW TRANSPORT. This way you get fresh load belts and tracking drive assly too. At any time replacing the laser, remember to check for(and remove) a solder short circuit across the laser diode to protect it from damage by electrostatic discharge. Do this after you have installed the loom if possible. And of course work electrostatic safe, at least GET A WRIST BAND while you are getting the spares.
My Stanton STR8-60 is not tuned correctly. I need help trying to get it to hold the right rpm for the platter.
You know it isn't for playing records. It is made for DJ Scratching from the 1980s.
Str8-60, any facts of info?
Vinyl Engine
https://www.vinylengine.com > viewtopic
Feb 18, 2012 - The s
tr8-60 is the bottom of the line dl deck from stanton, and has straight tonearm. it is
designed for dj use and is not really suitable for ...
AT150MLX on Stanton STR8-60? - Vinyl Engine
May 25, 2016
Ground wire repair on Stanton STR8-60 - Vinyl Engine
May 5, 2021
Stanton STR8-60 Replacement Power Cable - Vinyl Engine
1 post
Apr 18, 2021
Picking a cartridge with a turntable with no anti-skating
Mar 31, 2015
More results from www.vinylengine.com
stanton str8-60 : r/turntables
Reddit · r/turntables
2 comments · 9 months ago
The
STR8 turntables have a totally straight tonearm designed for DJ "scratching". If you just want to listen to records, they're not good ...
$50 Stanton STR8-60 got picked up today; all it needed was a ...
May 20, 2021
Stanton STR8 any good? : r/vinyl - Reddit
Oct 29, 2015
Stanton turntable model str8-50 vs. AT LP-60? - Reddit
Nov 13, 2023
Two Stanton T.60's and a M.202 mixer for $150? : r/DJs - Reddit
Jan 11, 2019
More results from www.reddit.com
How do i replace burnt fuses on stanton t62 m2 turntables
If they are the glass type fuses then they might still have the wattage on the metal ends.
However that might be the least of your problems. Fuses blow like that due to an overload. So you should look around for a shorted device such as a power transistor or anything having an heat sink on it.
