20 Most Recent
Annovi Reverberi Rmw 2g24 Vertical Shaft Pressure Washer Bare Pump Questions & Answers
Low Pressure
Very little info to go on here. Could be a valve issue or a packing issue or an unloader issue. If it has been sitting for any length of time which tends to be the case, then an unloader valve is most likely the culprit. Good luck
Water comes out of detergent port
detergent valve is ball bearing and spring. make sure its clean and the right way around and damage free.hunting can be caused by incorect idle, and is normal if machine is building up pressure when not being used.
