20 Most Recent
Acer Aspire T120 PC Desktop Questions & Answers
How to assemble the aspire T120c desktop
Install IO headers for power & reset switch, LED' some-times written on board or find diagram in manual.Basically install power, 20 or 24Pin power connector.Install 4Pin CPU power connector.Install data cables for Hard drive and CD drive.A video may be found on You-Tube.Take care!damnor01
My sound doesn't work
you need tofind the correct driver for your sound card look at driver detective.com
Acer t120 factory settings
hi...to restore pc to factory setting u need to have the CD for operating system installed in ur pc....if u have the CD please insert CD and keep tapping f12 and then press any key to boot from CD...there u get 2 option either to reinstall OS or to repair the PC ...u can choose repair option first if it fails then clean install the PC
Factory settings
if u have XP already installed then click start and right click on icons and select show on desktop,,,,else restart PC and keep tapping f8....you will see a black screen with safemode option try entering safe mode...if fails then u will need XP cd to repair windows
Hi
We have an Acer T120
Hi Jean,I don't believe it would be economically viable for you to purchase the front panel which houses the on/off switch. This may prove costly.I would rather look out for a new case with power supply and transfer your motherboard etc. to the new case.You should be able to get a new case & power supply from your local PC shop for under $50.Best wishes,Graemevm
Wont power up
try to isolate the problem 1st the power supply, if you have an extra pc try to remove the working power supply and put it to a non-working pc, same thing with the memory and video card, remember one a a time to figure out what is really problem ok, i hope this simple tips will help you to solved your problem : )
Where can i get a
You can visit computer shop, they usually carry a stock or one can be ordered for your system.
Can i install a sound driver.
If you visit Acer's website and look under their Support you can find the driver for that model.
Just put the model name into the search field and download the latest sound driver (usually they're called Audio Drivers)
Thanks!
I forgot my password what disc do i need to buy
if its the windows password you forget , the one it asks before logging into windows then you may be able to override it by booting into safemode (press F8 before windows starts) and then choosing to log into administrator instead of your own account, then click start > control panel >user accounts. Choose your account and then click on remove password. Then just restart the pc and you wont be prompted for a password. This will only work if you have not set your account as the only administrator.
If you found this info useful please vote for me
Greetings,
I beleive updating the drivers would resolve your problem. Visit the following link and download the sound drivers again on your system.
http://download.cnet.com/Realtek-AC-97-Audio-Driver-XP-W2K-W98-WDM-driver-VER-5-10-0-5554-zip/3000-2110_4-210198.html
This should resolve your problem. Request you to grade my answer in case you find it useful.
Have a nice day !
Regards,
Ask_Aby
When i boot from cd with my t 120 restore discs in
I would suggest making sure the discs are in prestine condition and also that your your cd rom is clean as well if nothing happens still you should contact the manufacturer about maybe downloading the restore disc to another media i.e. zip drive or external HD and simply boot from that to do a restoration
