20 Most Recent
GE Profile PXCF22RBS Hot and Cold Water Dispenser Cooler Questions & Answers
I have a GE Electronic
The Ge air purifier does not use a electro static precipitor, it uses a HEPA filter to catch the dust and dirt and it is not supposed to spark unlike the ORECK which does use the electo static precipitator
Is this a good model # for a GE electrostatic air
not likely the electrostatic air cleaners are discontinued for the most part because the really didnt do all they claimed. you can achieve much better air quality from a standard media air filter with a merv rating of 10 or better.
I need UV replacement BULB , I cant find one online
There are a few things you can try if you're having trouble finding a replacement UV bulb for your device online. One option is to check the manufacturer's website to see if they sell replacement bulbs directly. Many companies will also list authorized resellers on their website, so you may be able to find a replacement bulb from a trusted third-party seller.
Another option is to try searching for the bulb using the model number of your device. This will help ensure that you're getting a replacement bulb that is specifically designed to work with your device.
You can also try searching for the bulb using keywords related to the device, such as "UV water purifier bulb" or "UV air purifier bulb."
If you still can't find the right replacement bulb, you may want to consider contacting the manufacturer directly to inquire about replacement options. They may be able to provide you with the information you need or point you in the direction of a trusted reseller.
If online search not working you can try a local store that sell electronic part, Home improvement stores that carry a variety of lighting options may be able to help you find the UV bulb you need.
Please do let me know the model number or application the UV light is used for, so that i could provide specific recommendations.
