20 Most Recent
Craftsman 5600 watt Generator Questions & Answers
White smoke
You are getting oil into the cylinders. Possibly bad seals on the valves or bad rings on the pistons.
Governor not working
make sure oil level is correct and viscosity. check governor arm for binding if loose and floppy internal mechanical damage. If you have the electronic governor actuator on your model then need to check for battery voltage on it, if present actuator bad, if not control board
High idle
most cheaper generators do not have a idle kick down and are made to run at 1850 rpm's the older ones run at 3600 rpm if it has a no load idle system there will be a switch
