20 Most Recent
Genius USB ColorPage-Vivid 1200XE 1200dpi Flatbed Scanner Questions & Answers
Scanner
Driver Genius will automatically scan and find the official
ColorPage-HR6X Slim driver matching your needs - no matter what windows
version you're using.
Now you can finally use the same driver update tools used by PC
technicians and eliminate any guess work and time waste in the
process of updating your drivers. No more headache and no more countless
hours looking for help in hardware manufacturer sites
How do I install colorpage-vivid3x on windows7
Assuming that you have the driver but not for windows 7 ..there is a possibility for this to work ,,if you copy the driver into the hard disk ...and change its properties..I never looked if there is a driver for windows 7 released by the manufacturer..but usually there are no drivers for older products..so the thing to try is like I said ..First insert the disk ..and copy its content on a location on the computer ..After that ..open the folder ..and look for the executable (install ) icon ...and click right on it ..and choose properties..and in that windows. choose compatibility ..and inside ..choose to run in compatibility with windows xp (if the driver is built for windows xp ) ..and afer that click apply ..and ok ..and run the driver..It may give you a error ..and say it is not compatible ...and after that give you the choice to run it in compatible mode..so choose this version ..and always select to run it anyway no matter what the windows says about it ..when you finish ..just restart after you connect the device too ..(you may connect the device before installation ..but the restart may be critical for functionality ..let me know if it makes issues and do not want to work ..
http://downloads.kappa.ro/drivers/scaner/genius-colorpage-vivid-3x-xe.htmlthis is supposed to be the driver for it ..but like I said I dont think it was made for windows 7 so ..try like I said Have a good day !Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.Thank You.
We have people ordering for
Yes! But you'll have to set up a designated file server for it to work smoothly, using Windows Server with Active Directory configured.
