20 Most Recent
Vapor WhiteWing Steamer Canister Vacuum Questions & Answers
Hi -- For my White
Re: Low pressure on WhiteWing steam cleaner1. Make sure the safety switch for the hose handle on the right side of the hose handle is turned to the closed position. To do that, push it away form the hose.2. Make sure the steam release button (next to the on/off button on the control panel on the steamer) is in the Off position. 3. Make sure the safety cap is tightened.4. Make sure you have enough water in the tank (at least half a bottle of water)I hope this helps.
I need operating manual for vapor white wing steamer
This is from an Amazon review. I have misplaced my manual and was searching for a pdf file without any luck. I think I have it under control if I only knew where to put my distilled water.Basic operation of the WhiteWing is: 1. Fill the tank with distilled water 2. Attach the hose to the steamer. 3. Attach the extension handles and attachment you want.(Be sure to watch the video and read the instruction booklet. Some of the attachments have specific uses and setup instructions) 4. Lock the finger trigger. 5. Plug it in. 6. Turn it on. 7. Wait 20 min. or until the pressure gauge reads between 3.5-4.5. 8. Get ready to rock - press the steam release button, unlock the finger trigger and start steaming. For many jobs such as countertops, shower stalls, stovetops, you will need to follow behind the steam, wiping with a cloth to remove the released dirt from the surface. Some jobs may require you to start with a non-toxic cleaner or grease remover such as Orange Clean or Method brand cleaners. Remember, you'll be breathing in vaporized cleaner. So be sure it's something non-toxic and non-irritating. I prefer the Method brand cleaners.
How do i fix a vacuum line hose on a car that's been cut?
Alot depends on the type of hose. There are plastic hoses and rubber hoses. Generally you can use a smaller plastic connector to connect two rubber hoses together and visa versa, Make sure it is a snug fix. You could also use an adhesive to keep it together.
3/31/2024 3:39:13 PM •
Vacuums
Answered
on Mar 31, 2024
How to empty a etl vc-h3301 vacuum cleaner
How to open it to see if the fuse is blown. I removed the three screws I saw. I feel that there is another which prevents me from opening it in two. I looked under the tights, I removed the plate where the two buttons are located. I can't open it.
3/21/2024 4:57:04 PM •
Vacuums
Answered
on Mar 21, 2024
