why?isn`t difficult. first connect ac power.then,load drivers from cd/dvd.when asking,connect printer via usb cable and in few minutes will be ready for printing.
There is an installation process that you have to follow when installing these. First uninstall it, you should see if there is any other printers installed on the machine too and remove those. Then unplug the printer and restart the computer. Install the printer software on the computer and when it is done, then turn the printer back on.
Gently clean the contacts in the carriage, and on the cartridges with a paper towel or coffee filter moistened with water.For the poor print quality or missing print:Perform the Blot TestRemove cartridge from machine, fold a paper towel back over a couple of times so it is about 4 layers thick, shake cartridge up and down hard, shake it over a sink unless you want to clean ink off the floor.Now blot the nozzles of the cartridge on the paper towel, for a black cartridge you should see two black stripes, for a color cartridge you should see three colored stripes, if you don't have all stripes the cartridge is clogged or bad.Have you checked the expiration date on the cartridges you are using?Are you installing new HP cartridges, or refills?You may be able to recover a clogged cartridge by swishing the tip in a saucer with a very small amount of warm water, then gently wiping it on a wet paper towel, be gentle the nozzles are delicate.And do not trust the ink gauge on the PC, cartridges can dry up from the machine just sitting, the cartridges are vented, venting is necessary to let air in so that a vacuum won't develop in the cartridge.Mercedes Parts.
If you have followed the manual instructions for removing wrinkled paper from your HP Color Laser MFP 179fnw printer but cannot locate it, you can try the following steps:
Open the printer: Turn off the printer and unplug it from the power source. Open all accessible panels and trays of the printer, including the front cover, rear cover, and paper trays. Carefully inspect these areas for any visible signs of the wrinkled paper.
Check the paper path: Carefully examine the paper path inside the printer. Look for any jammed or crumpled paper along the path, including the input tray, output tray, and any internal rollers or guides. Gently remove any visible paper debris that you find.
Use a flashlight: If the wrinkled paper is difficult to see, you can use a flashlight or a bright light source to illuminate the paper path. This can help you spot any hidden or hard-to-reach areas where the paper might be stuck.
Check the fuser area: The fuser is a heated component in the printer that bonds the toner to the paper. Sometimes, wrinkled paper can get stuck in the fuser area. Refer to the printer's manual for instructions on accessing and inspecting the fuser unit. Be cautious as the fuser can be hot.
Use a flat tool: If you still cannot locate the wrinkled paper, you can try using a flat tool, such as a plastic ruler or a piece of stiff cardboard, to gently guide through the paper path. This can help dislodge any hidden paper that may be causing the issue.
Contact customer support: If you have exhausted all your options and are still unable to locate and remove the wrinkled paper, it may be best to contact the customer support for your HP printer. They can provide further guidance and assistance in resolving the issue.
Remember to always follow proper safety precautions and refer to the printer's manual for specific instructions related to your model.
If your HP LaserJet 1200 printer is experiencing intermittent printing issues, there are a few steps you can take to troubleshoot and resolve the problem:
1. Check for paper jams: Even if you don't see any visible paper jams, it's worth opening up the printer and checking for any small bits of paper or debris that might be causing a partial blockage. Use a flashlight to examine the paper path thoroughly.
2. Clean the paper path: Over time, dust and debris can accumulate in the paper path, leading to printing problems. You can use compressed air or a soft, lint-free cloth to gently clean the rollers and other accessible parts of the paper path.
3. Verify printer drivers: Ensure that you have the latest printer drivers installed on your computer. Outdated or incompatible drivers can cause printing issues. Visit the HP website and download the latest drivers specifically for the HP LaserJet 1200 printer model.
4. Reset the printer: Perform a power cycle by turning off the printer, unplugging it from the power source, and waiting for a few minutes. Then, plug it back in and turn it on again. This process can help clear any temporary glitches or errors.
5. Adjust printer settings: Check the print settings on your computer and ensure they are appropriate for the print job. Make sure you have selected the correct paper size, paper type, and print quality settings.
6. Update printer firmware: Visit the HP support website and check if there are any firmware updates available for your printer model. Updating the firmware can address known issues and improve the printer's performance.
7. Check for hardware issues: If the problem persists, there might be a hardware issue with the printer. Consider contacting HP support or a printer technician to diagnose and repair the printer.
Remember to consult the printer's user manual for specific instructions on maintenance and troubleshooting.
this might help
