20 Most Recent
DFI KM400MLV KM400 AUDIO/Video/LAN/USB/SATA/RAID/333FSB Athlon XP Motherboard Questions & Answers
No audio
if your computer came with
a motherboard disc the sound drivers could be on it
click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question mark? Right click to reinstall
drivers or uninstall
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar
if his does not fix the
problem
have you tried this control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer
make sure you have an earth
******** before touching any parts inside your computer
hope this helps
R67uiryfkfy
Please re-submit your problem with more details to describe what is the issue. Thank you.
DFI NB73EA no sound
Have you installed the audio drivers for your motherboard from the cd that was included with it?
Lou
Dfi games
http://www.gamesfree.me/games/tags/dfi/
Hackers unite
That will be a very big blob of goo! Or a very large and wobbly hacker.
