20 Most Recent
Frigidaire FRT125GW (12 cu. ft.) Top Freezer Refrigerator Questions & Answers
Why is Fridge Freezer not switching itself back on after 2 hours?
Good Afternoon S Trowell - Thank you for your post! Based on the symptoms you are describing it appears that the thermostat has lost its calibration and is not cycling on or off at the proper temperatures. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis and to proceed further.
FRT125GW warm fridge problem
Hello jumptrout51 - Generally speaking, if the compressor is on then the freezer fan should be on as well. Note that it does not indicate a failed fan motor. The fan motor receives power from the temperature thermostat. Therefore, at this point, I would personally recommend connecting with an experienced technician to determine the underlying cause.
Check the compressor on a fridgidair modle FRT125GW fridge
Hello flippedon127 - If you are requesting information on how to check the compressor regrettably, this is not a simple DIY job. The compressor is meant to run on a more constant basis; it is maintaining the temperature within the refrigerator, rather than having to cut off and start again to adjust temperature. However, if you do not hear the compressor running generally, qualified technicians often perform complicated part replacement such as this. Usually this type of information is not release to a consumer and very rare to find enough information to do it yourself. If I was in your position, I personally recommend contacting a professional to accurately assist with the repair or installation of the part.
Frigidaire Upright Freezer keeps cycling on and off in short cycles
It is called short cycling. Help below
If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on.
Apr 14, 2019
Possible Causes For a Short Cycling Refrigerator
A to Z Appliance Service
https://atoz1.com > News
I have a frigidaire freezer and its short cycling, it runs
JustAnswer
https://www.justanswer.com > Appliance Repair
Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ...
1 answer · Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Frigidaire S/S not cooling, short cycling
Appliance Parts Pros
https://forum.appliancepartspros.com > posts > t55646...
Freezer or fridge does not cool at all. Evaporator fan runs, compressor try's to start and will hum/buzz for approx 7-10 seconds then an audible click and stops ...
Refrigerator short cycling and not cooling very well
Appliance Video
https://www.appliancevideo.com > question > refrigera...
Compressor turns on during the short cycling and does produce cold air and cold lines going to the evaporator in the freezer. biggest thing is during the 3 ...
Frigidair freezer compressor cycling on/off
HVAC-Talk
https://hvac-talk.com > vbb > threads > 53155-Frigidai...
Mar 7, 2021 - My Frigidaire freezer (upright) Model #FFU13F9GW is cycling. I hear the compressor try to kick on then shuts off after about 10 seconds. This has been ...
Domestic Refrigerator Short-Cycling
Dec 4, 2020
Wiring time delay for a short cycling compressor
Jun 23, 2022
Walk-in short cycles
Mar 7, 2021
Walk-in compressor short cycling
Oct 20, 2008
More results from hvac-talk.com
