20 Most Recent
Sony HT-DDW750 System Questions & Answers
Sorry for the bad news. It probably needs an output ic replaced.
Sony HT-DDW750...
Answered
on Feb 23, 2009
I would suspect the lead from your tv or video and swap this.ie where are you feeding tv signal to amp from.more than likely faulty lead or socket at this point.swap around the leads and see does fault transfer to the opposite channel.keep with it sounds like set up problem of some sort,.
Sony HT-DDW750...
Answered
on May 20, 2007
Mechanism is jammed or loading motor has failed.
Sony Audio...
Answered
on Apr 03, 2021
The loading process is out of sync, most likely because of a stretched belt in the mechanism. This is a common problem with Sony "jukeboxes".
Sony Audio...
Answered
on Mar 15, 2021
what need to do is go into the settings menu and find the section on sorting it out or you could do a factory reset. That should get you sorted..
Sony Audio...
Answered
on Mar 08, 2021
blown fuse inside from outputs if no fuse bad outputs
Sony Audio...
Answered
on Feb 28, 2021
As far as i know, there is no solution to this, sorry
Sony Audio...
Answered
on Feb 25, 2021
That may be a non factory modification. Get a small battery and take one pair of those wires and connect to the battery with you fingers on the stripped end of the wires. Listen for scratchy sound and the front and then try the other pair of wires. This will give you an idea on that is going on inside the speaker. Short of using special equipment or opening the speaker enclosure, there is no easy way to tell.
Sony Audio...
Answered
on Feb 08, 2021
Your Sony receiver is in protect mode due to component failure internally.
Sony Audio...
Answered
on Feb 05, 2021
Repair the damaged amplifier.
Sony Audio...
Answered
on Jan 30, 2021
Check the back for a fuse?
Take it to a Sony Service Centre.
Sony Audio...
Answered
on Jan 22, 2021
