20 Most Recent
Chauvet Intimidator 1.0 Dmx-600 512 Scanners Questions & Answers
Intimidator light wont come on
I have 6 of these in my lighting rig, and the most common problem has been a bad bulb socket. If your bulbs end up with corroded or blackened terminals, you should replace the socket. The black/corroded stuff can cause the connection to become intermittent, sometimes so badly it entirely doesn't work. The other common problem I've seen involves a resistor on the circuit board that powers the light bulb. I believe it's R2 - regardless it's the only big one. It's value is .5 ohms at 3 watts. Be sure to use a flameproof resistor when replacing it, and most likely your fixture will light up again.
3/22/2012 3:21:09 PM •
Chauvet...
Answered
on Mar 22, 2012
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
