20 Most Recent RCA VR546 S-VHS VCR Questions & Answers
Remote code control manufactureer vhs universal
Get a replacement from www.tvassist.co.uk, call them if not listed and they will get it listed for you
11/18/2013 7:02:02 PM • RCA VR546 S-VHS... • Answered on Nov 18, 2013
manual
Err message
There could well be some damage inside the VCR that is causing the system to go out of sync. Also the mode switch might need replacing.
11/28/2012 12:42:10 AM • RCA VR546 S-VHS... • Answered on Nov 28, 2012
I need to know how to hook up my vcr to my dvr to
Ok. You connect the vcr to the televison first. Take an rca cable and connect it to the video out of the vcr then connect the other end to the av input on your television. Then take another set of RCA cables and connect them to the RCA av input on your vcr and connect the other end to the output on your dvr.
Now hopefully your tv has another RCA input you can hook directly to the dvr with another set of RCA cables to another one of the dvrs outputs. If not then don't worry about that.
Now make sure the tv is switched over to the av video RCA input the vcr is connected to and turn the vcr on. The vcr should be in input and when it is you will see the picture from your dvr and you will change channels with your dvr remote. You can now record using the vcr remote.
6/14/2010 4:25:26 PM • RCA VR546 S-VHS... • Answered on Jun 14, 2010
2answers
Timmer recorder doesn't work - rca vr546
hi,
for clarification, did you got a video and sound coming out on the tv?
2/9/2009 6:24:47 PM • RCA VR546 S-VHS... • Answered on Feb 09, 2009
Connecting vcr to tv
Find Video & Audio Out pins at back of Combo player. This is output signal which will be connected at Video & Audio Input at front of TV. Watch out video pin will go to video input. Now select AV input of TV by remote. Usually its AV-4.
Have fun, or need more info, let me know the out comes.
10/22/2008 5:31:48 PM • RCA VR546 S-VHS... • Answered on Oct 22, 2008
Diagonal lines
Hi It's difficult to be sure without being able to see the lines myself, but what it sounds like is some stray RF is getting into your video signal. Although your cables are supposed to be shielded, this is a common problem. The first thing I would do is move the cables or cable you are using, in relation to any power cords hanging down behind your equipment while someone watches for the lines to change or dissapear, and is that has no effect, then if possible change the position of the VCR in relation to the tv, so that if for example it is under the tv, move it to the side, or farther away, and the lines may very well dissapear. That problem is due to a common interaction between the tv and vcr where there is not enough shielding, usually inside the bottom of the tv set. Hope this helps, good luck!
2/17/2008 3:54:35 PM • RCA VR546 S-VHS... • Answered on Feb 17, 2008
Set up with daytron TV
Have you tried hooking up the VCr and TV using RCA cables? You must connect Video out from VCR to Video IN of Tv and Audio out of VCR to Audio IN of TV.
6/9/2007 3:27:42 PM • RCA VR546 S-VHS... • Answered on Jun 09, 2007
2answers
Powers up but shuts down when play button is pressed RCA YLG43E
Try to check the power supply output side where anything could came into contact with positive and negative line for which when you press play button then it shuts down.
3/25/2024 6:44:15 PM • RCA Televison &... • Answered on Mar 25, 2024
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.) I hope this helps. Cindy Wells (One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3/24/2024 11:03:58 PM • RCA Televison &... • Answered on Mar 24, 2024
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
2/23/2024 10:21:26 AM • RCA Televison &... • Answered on Feb 23, 2024
2answers
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI copy and paste link for manual https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
2/18/2024 4:51:27 PM • RCA Televison &... • Answered on Feb 18, 2024
2answers
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them. Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
2/2/2024 11:35:38 PM • RCA Televison &... • Answered on Feb 02, 2024
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse . TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
1/21/2024 8:13:40 PM • RCA Televison &... • Answered on Jan 21, 2024
What is the code for remote control for RCA model# RT 1971-AC
Better idea https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Replacement Remote Control for RCA DETG160R ...
Amazon.com https://www.amazon.com > Replacement-DETG160R-... Replacement Remote Control for RCA DETG160R DETG190R RT1971-AC RLDED3932ARK LCD LED HDTV TV - ( Compatible Model: DETG160R ) ; Controller Type. Button Control. US$32.99 · ‎In stock
RCA RT1971AC Replacement Remote
Remotes.net https://www.remotes.net > products > replacement-rem... If your original RCA remote has died, been destroyed or lost, or has simply stopped working, this replacement RCA remote can be the solution to your problems. US$34.90 RCA Universal Remote Codes:
  • The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
  • The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
  • The cable box codes are: 000 and 027.
Apr 26, 2023
RCA Universal Remote Codes List 4 Digit - GenTwenty
12/27/2023 12:47:10 AM • RCA Televison &... • Answered on Dec 27, 2023
Rca remote r26211 code for trutech tv dvd
Better to get a Facsimile Remote, a copy made for the unit. It is unlikely, you can input codes to work both applications in a combined set.
TruTech TV universal remote control codes (3, 4 and 5 digit)
eliztech.com https://www.eliztech.com > remotes > codelists > trutec... Universal remote codes for TruTech TV sets - 3 digit, 4 digit and 5 digit codes.
My mom has a Trutech combination TV/DVD, about 20 ...
JustAnswer http://www.justanswer.com > TV Problems Feb 6, 2013 - There are very few universal remotes that will operate a tv/dvd combo and of ten if you find a code then the tv a dvd have separate codes. 1 answer · Top answer: Jack : Hi and welcome to justanswer. To answer your question; There are Make sure you use the FULL Model Number for it.
TRUTECH TV Replacement Remote
Remotes.com https://www.remotes.com > trutech-remote-controls-s Replace new & discontinued remote controls for TRUTECH devices with fully programmed remotes from our online store. Enjoy low prices and fast shipping.
Trutech Remote for sale
eBay https://www.ebay.com > ... > Remote Controls Sort ; 2PCS Remote Control For TruTech KLV3170 LCD Drop Down TV Built-in DVD Player · $13.83 ; TruTech A60P0315 Remote Control Genuine OEM TESTED · $3.00 ; Original ...
Trutech Remote Control
Amazon https://www.amazon.com > trutech-remote-control > k... GE Universal Remote Control for Samsung, Vizio, LG, Sony, Sharp, Roku, Apple TV, TCL, Panasonic, Smart TVs, Streaming Players, Blu-ray, DVD, 4-Device, ...
12/20/2023 1:17:20 AM • RCA Televison &... • Answered on Dec 20, 2023
I dropped my RCA remote control, how can I reestablish connection with Magnovox tv?
Check that the batteries haven't become disconnected. Do the Smartphone camera test to see if it is transmitting a signal. If it isn't, buy a remotes specially made for the Magnavox rather than an RCA Universal. Google Magnavox (model) remote control replacement. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
11/30/2023 4:26:09 PM • RCA Televison &... • Answered on Nov 30, 2023
My old Panasonic TV set has no video RCA slot. Only audio R and L slot available.
tv is not a smart tv, may have to replace it.
11/27/2023 3:30:48 PM • RCA Televison &... • Answered on Nov 27, 2023
RCA VR546 S-VHS VCR Logo
12 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
err message
  • Televison & Video
