20 Most Recent Leisure Cuisine Master RCM10FRSP Silver 1000 mm Dual Fuel Range 53 l 24 l, A Energy Rating Questions & Answers
How do we stop our cooker from squeaking when off?
Question edited for clarity, wrong version of duel/dual. Please always include full make model details. That will be the clock if it is an analogue electric clock.. It needs lubrication. Or if it has a rotisserie function, the rotisserie motor is running Or if the dual fuel is pellets, the auger is squeaking. It is all guesses without make model details, but you get the idea. ..
8/23/2023 3:41:44 AM • Leisure Kitchen... • Answered on Aug 23, 2023
Oven door on my Leisure Cookmaster101 wont close tight enough , how do I correct this problem?
If it's as old as ours the holes the hinge pins locate in have enlarged over time. This makes them sloppy. If you lift the door, is there a lot of up n down movement. Not closing properly will make the coven less efficient. I'm in the process of researching the parts required before Xmas. So we don't have a cooker failure on the big day??
11/5/2022 7:03:48 PM • Leisure Kitchen... • Answered on Nov 05, 2022
I changed my door hinge on my leisure cookmaster CM19FRC & now can’t screw it back on, it seems to have lost the rivets built in on the inside
I have the same problem. I think there is a plate with threaded holes behind the panel that the screws screw into, and this plate falls when you remove all 3 screws. But I cannot see any way of getting behind the panel to retrieve this plate. Help!
10/16/2022 9:24:55 PM • Leisure Kitchen... • Answered on Oct 16, 2022
Where is the fuse in a 2 oven leisure cooker
You main 'fuse' is the breaker. It does have a thermal fuse, but that has a different function. Information and videos that may help, but in questions like this a full make and model number are needed. https://www.google.com/search?q=leisure+cooker+with+2+ovens%2C+fuse ..
11/14/2021 8:42:17 PM • Leisure Kitchen... • Answered on Nov 14, 2021
I have a leisure cooker with 2 ovens and want to know where the fuse is located
The fuse is in your consumer unit. There is no fuse in the cooker itself.
11/14/2021 5:55:56 PM • Leisure Kitchen... • Answered on Nov 14, 2021
Flame stays high will not turn down on knob s to 9 range master leisure 55.
https://www.youtube.com/watch?v=gHi9y5iNAC0
4/3/2020 5:00:10 PM • Leisure Kitchen... • Answered on Apr 03, 2020
I HAVE SMOKING AND NOISE FROM MY FAN ASSISTED OVEN. THERES A GRINDING NOISE OFF THE FAN ALSO
Sounds like fan motor bearings have died. You can likely search for a new fan online.
1/31/2019 5:55:16 PM • Leisure Kitchen... • Answered on Jan 31, 2019
I've has the connection from the hose/cooker tightened which got rid of gas leak showing on a meter. Still smells. No leak at bayonet. Should I replace the 9 year old hose on Leisure 101 Cookmaster.
would be a safe action as hoses perish and leak if the smell persists get in a gas fitter with a sniffer meter to find the leak
5/13/2017 9:41:07 AM • Leisure Kitchen... • Answered on May 13, 2017
Leisure Cuisine Master RCM10FRSP Silver 1000 mm Dual Fuel Range 53 l 24 l, A Energy Rating Logo
1 questions posted
Top Leisure Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Leisure Kitchen Ranges
Most Popular Question
  • Kitchen Ranges
