Question about Leisure Kitchen Ranges
Hi i have a leisure cuisine master 100 range cooker and i want to no how to get the front panel off so i can fit new knob for oven plz
Posted by keith norsworthy on
4 Related Answers
protek480
Craig Butler
  • 1730 Answers
SOURCE: how to fit main oven door on stove 1200 Range cooker 100 DFA
Open the door part way, then grasp the door on either side and lift up and out to release the hinge.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 13, 2009
Anonymous
  • 82 Answers
SOURCE: i have a ge xl44 gas range. the oven knob has come off
You will need to locate your full model #, usually open the bottom drawer and you can see it on the chassis on the right or left side. Try searspartsdirect.com type your model in and it will give you a parts breakdown and about the best assembly view your going to get. Sometimes there is more to be desired but this should help. Please rate this post.
Posted on Dec 14, 2009
FitzOriginal
Chris Hall
  • 842 Answers
SOURCE: what kw is my leisure
If this is the RCM10CR model with electric hob and oven than it has a maximum rating of 13.8Kw (Page 6 of the manual, a pdf of which can be found here: http://www.leisurecp.co.uk/upl/31115-RCM10CR.pdf )
If it is the dual fuel RCM10FR then it has a maximum rating of 7.7Kw (page 6 of the manual, a PDF of which can be found here: http://www.leisurecp.co.uk/upl/55403-RCM10FR.pdf )
Posted on Jul 28, 2011
ray gallant
  • 67876 Answers
SOURCE: I have a leisure cuisine master 100 and the clock/timer is dead and my fan oven is not working can the clock be bypassed
Not if you ever want to bake anything .and have it turn off at a set time
Posted on Dec 05, 2015
I cant find my model number and serial number for my new cuisine master 100
Serial number should be on a rating label on the appliance.
The model number should be in the instruction manual that came with it.
Possible company phone numbers in a similar model manual:
https://www.manualslib.com/manual/991745/Leisure-Cuisinemaster-Cs100f520.html?page=37#manual
Jul 23, 2018 | Kitchen Ranges
What do I need to do to screw the oven door back to my leisure Alta cooker? Any suggestions?
Try hooking the plate with a piece of wire and pull it close to the hole's,then get a strong magnet and put next to the screw holes,it might hold the plate till you get the screws started.
Jul 20, 2014 | Leisure GRB6CVK Electric Cooker with...
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
What kw is my leisure cuisine master 100
Jul 28, 2011 | Ovens
Just bought a Leisure Gourmet Classic gas cooker. Connected the gas and plugged it in but none of the burners will light. The ignition is working but no gas is getting through. Any ideas folks? TIA, Andy
I had a similar problem when my new Leisure cooker was installed last December. The burners would light when I held the knobs in but when I let go the flame would go out. The engineer took off each of the burner knobs and stuck a small wad of aluminium foil between the inside of the knob and the contact on the front of the cooker - he said it's a design fault and the gap is just a bit too large for contact to be made reliably. This fixed the problem and I've had no trouble since.
Jun 22, 2010 | Ovens
I have a Beko 'Leisure alta AL6ND' oven. The thermocouple has gone in the oven (ignites but not staying lit, all other burners and grill fine). I can get the back off easily, but the thermocouple screws in...
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
Dec 01, 2009 | Ovens
Both ovens on my leisure rangemaster 100 will not come on
phone rangemaster they can advise how to change the spark in egnition and supply bit. 08707 895 107
Jan 23, 2009 | Rangemaster 110 (Gas) Kitchen Range
Kitchen Ranges Logo
35 people viewed this question
Top Leisure Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
Chuck Graybill
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
