PROBLEM :-The power supply of the projector is faulty there is a
transistor witch is switch 15 volts for the lamp drive board.
SOLUTION: Remove the upper cover with 6 screws back side of the projector.
remove main board and lamp cover with 7
screws.(show in the picture)
remove upper cover of the power supply and lamp drive unit with 3 screws.
remove power supply unit with 4 screws and 3 connectors and put face down on the table.
now you find the
transistor no Q107 and replace with the transistor no 2SB710 is and
surface mounted compunent(show in the picture)
fix it all as you open.
power ON the projector and enjoy
(doing very carefully This is a technical job)
