Panasonic PT-LB10SVU Multimedia Projector Logo
A
Anonymous Posted on Jun 17, 2011
How to clear the counter hours lamp? - Panasonic PT-LB10SVU Multimedia Projector
Anonymous
Level 2:
  • Expert 442 Answers
  • Posted on Jun 18, 2011
Anonymous
Expert
Level 2:
Answers
442
Questions
Helped
176817
Points
703
Use the menu,
select main menu, option 2, lamp runtime, then press and hold the enter button for 3 seconds. after it resets, turn power off.
1helpful
On screen message "lamp life over, error!!, which
Hello John:
If you replace the DLP lamp out of your Zenith or LG, you will need to reset the counter...otherwise you may get an annoying reminder every few days if you're surpassed the predetermined hour mark.
To Reset:
Ensure the TV is powered on.
1) Press and HOLD the MENU button on the TV
2) Press and HOLD the MENU button on your REMOTE
(hold both these until the service menu pops up 5-10 secs max.)
3) Let go of the REMOTE button first, then release the button on the TV
4) Press and HOLD the ENTER (or OK) button on the TV
5) Press and HOLD the MUTE button on the REMOTE
(hold both until the LAMP LIFE HOURS appears on the screen)
6) Let go of the REMOTE button first, then release the button on the TV
We suggest writing your lamp hours on a piece of masking tape and taping it to the back the TV for future reference.
7) To reset the lamp counter, press SELECT (or the button in the middle of the direction arrow buttons). Hit SELECT a second time to confirm clearing the lamp counter
For certain models, you might have to tweak these steps slightly...
tip
Lamp Reset Procedure for LG and Zenith Televisions
You have replaced your lamp and the set is working fine but the 'replace lamp light' is still on. What do you do?
This is an important procedure because you need to know when it is time to replace the lamp again. If you do not reset the timer you may run the risk of having the lamp explode, because it was not replaced in time. This can be dangerous and could cause a fire.
To reset first make sure the TV is powered on.
1) Press and HOLD the MENU button on the TV.
2) Press and HOLD the MENU button on the remote.
Hold both these until the service menu button pops up. About 5 - 10 seconds max.
3) Let go of the REMOTE button first, then release the button on the TV.
4) Press and hold the ENTER (or OK) button on the TV.
5) Press and HOLD the MUTE button on the REMOTE. Hold both until the LAMP LIFE HOURS appears on the screen.
6) Let go of the REMOTE button first, then release the button on the TV.
I suggest writing your lamp hours on a piece of masking tape and taping it to the back of the TV for future reference.
7) To reset the lamp counter, press SELECT (or the button in the middle of the direction arrow buttons). Hit SELECT a second time to confirm clearing the lamp counter.
For certain models you may have to try different buttons or tweak the steps slightly.
This should reset your counter and you will be ready to enjoy your TV for about another 8000 hours.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
on Jan 29, 2011 • Televison & Video
tip
Lamp Time Reset for LG TVs
If you replace the DLP lamp out of your LG, you will need to reset the counter…Otherwise you may get an annoying reminder every few days if you’re surpassed the predetermined hour mark.
Press and hold the MENU button on the TV
Press and hold the MENU button on your REMOTE
Press and hold the MUTE button on the REMOTE
To reset the lamp counter, press SELECT (or the button in the middle of the direction arrove buttons). Hit SELECT a second time to confirm clearing the lamp counter
For certain models, you might have to tweak these steps slightly… offer your inputs!
on Mar 24, 2010 • Televison & Video
14helpful
How to reset lamp timer on Toshiba TDP-T45
Reset the LAMP COUNTER HOURS:
1. Turn off the projector and unplug the power cord.
2. Press and hold down the three buttons at a time (ON/STANDBY) (MENU) and (INPUT) and plug in power cord.
3.The lamp hours counter will automatically turn to zero
4. Now you press POWER BUTTON and after warm up you check lamp operation counter in the STATUS display it should be "0"
31helpful
4answers
HI I WANT SERVICE CODE OF INFOCUS LP600 ASKC175
I am not exactly sure what service code you are searching for, what is happening with the projector? You turn it on and immediately it's looking for a code? Please let me know and I can help
Tim
tip
Reset your TV Lamp--------> ZENITH <----------------
If you replace the DLP lamp out of your Zenith or LG, you will need to reset the counter…Otherwise you may get an annoying reminder every few days if you’re surpassed the predetermined hour mark.
  1. Press and hold the MENU button on the TV
  2. Press and hold the MENU button on your REMOTE (hold both these until the service menu pops up 5-10 secs max.)
  3. Let go of the REMOTE button first, then release the button on the TV
  4. Press and hold the ENTER (or OK) button on the TV
  5. Press and hold the MUTE button on the REMOTE(hold both until the LAMP LIFE HOURS appears on the screen)
  6. Let go of the REMOTE button first, then release the button on the TV We suggest writing your lamp hours on a piece of masking tape and taping it to the back the TV for future reference
  7. To reset the lamp counter, press SELECT (or the button in the middle of the direction arrove buttons). Hit SELECT a second time to confirm clearing the lamp counter
How do i reset lamp hours for a toshiba TLP-T721
I have not actually tried this but on a different post, here's the wild solution:
Reset the lamp counter hours of operation for the projector TOSHIBA TLP-T720
1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord
3. The lamp operation counter will automatically turn to zero
4. Check if the lettering "0H" appears on the lamp operation counter in the status display
5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
9helpful
How to reset the DLP TV Lamp Counter
We suggest writing your lamp hours on a peice of masking tape and taping it to the back the TV for future reference.
To reset the lamp counter, press SELECT (or the button in the middle of the direction arrove buttons). Hit SELECT a second time to confirm clearing the lamp counter For certain models, you might have to tweak these steps slightly…offer your inputs!
1helpful
2answers
Replacing lamp
try this to see if it works!
2helpful
2answers
Zenith Lamp Light on
When the lamp is replaced the lamp timer must be reset. The timer is set for just so many hours and then the warning lamp is illuminated. The only way to reset the lamp that I am aware of is with a zenith programmer remote. Perhaps you can find a local lg/zen service center to allow you to use a programmer and instruct you on resetting the timer.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
