20 Most Recent 2001 Suburban 1500 Heater/AC Control h71379052g roof mounted auxiliary, Passenger Side Rear, Manual temp control; roof mounted auxiliary, front, Manual temp control, w/sunroof San Francisco, California Questions & Answers
2answers
Why won't my heater in my 2001 chevy suburban wont blow hot air
The heater control operates a valve in the engine compartment allowing an adjusted amount of hot engine coolant to circulate thru the heater coil located in the heater fan box. If the valve is stuck in a closed position it will not let heated coolant pass thru the coil. Most often on vehicles with some age, the heater coil gets clogged by residue from heated coolant. If this is the case, try to back flush the heater coil. I have used a small pump and a coffee canister for a reservoir and attached temporary hoses and flushed a mixture of water and a type of radiator cleaner thru mine with much sucess. Try flushing for a few hours in one direction ...then, switch the hoses and flush in the other direction. It takes awhile , but is much cheaper than buying and installing a new heater core.
11/19/2014 3:56:51 PM • 2001 Suburban... • Answered on Nov 19, 2014
2answers
How to reset automatic sliding door on chevy venture van
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
  1. Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
  2. Manually open the power sliding door completely.
  3. Manually close and latch the power sliding door.
  4. Turn the power sliding door ON/OFF switch to the ON position.
  5. Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
  6. Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
9/9/2022 4:43:40 AM • Chevrolet... • Answered on Sep 09, 2022
Drum brakes 1998 s10
What is the question?
11/25/2018 2:32:16 AM • Chevrolet... • Answered on Nov 25, 2018
Torque specs 05 Chevy Silverado 1500 4WD front hub assy and axle nut
165 ft lbs
11/25/2018 2:26:57 AM • Chevrolet... • Answered on Nov 25, 2018
I tried the solution for the ast ultra remote car
It is still immobilized through the alarm system then.
8/29/2017 6:20:45 AM • Chevrolet... • Answered on Aug 29, 2017
4answers
Check engine light on says p2000 on code reader
The code is: P2000 NOx Trap Efficiency Below Threshold Bank1 and I do not know what that is unless it has something to do with the oxygen supply to the engine. Sorry I am not much help.
10/30/2015 6:24:22 PM • Chevrolet... • Answered on Oct 30, 2015
Shuts off while driving and looses all lights
sounds like the alternator is not putting out. If you start the car and remove the battery cable and the engine shuts off then the alternator is bad and you need to change it.
10/4/2015 7:09:19 AM • Chevrolet... • Answered on Oct 04, 2015
Sun visor removal
take the screws out of the arm and take it down.
10/4/2015 7:06:44 AM • Chevrolet... • Answered on Oct 04, 2015
2answers
Fuel cuoff switch
check everything else, I don't believe it has one
9/25/2015 3:12:56 AM • Chevrolet... • Answered on Sep 25, 2015
Switch wont turn
it that on the door the heater the radio the steering column or on your Sony Walkman??
3/26/2015 5:11:11 PM • Chevrolet... • Answered on Mar 26, 2015
How to turn off security
You tube that question, watch the video and disable it forever or get a new key
3/26/2015 5:10:09 PM • Chevrolet... • Answered on Mar 26, 2015
My 66 vett has a replacement vin plate special plate Pennsylvania issued 012874 why would this happen
Pennsylvania is totally messed up, I am sure you have found that out, you may need to find out where and who put the tag on the vehicle, ie, which notary , , , they are way behind the times the car may have been restored, you may never find out.... any other state could tell you with a single phone call to the local dmv, but not penn, all they do is drivers licenses
3/26/2015 5:09:23 PM • Chevrolet... • Answered on Mar 26, 2015
What wrong with my 1995 silverado it has starting problems
a long list of problems, please be more specfic and I can help you does the starter turn the engine yes or no if no, do you hear anything, even a click if yes check to see that you are getting fuel check to see if you are getting a spark and ask your question again giving answers to these and all questions you can think I may ask
3/26/2015 5:06:20 PM • Chevrolet... • Answered on Mar 26, 2015
2answers
Code po 443 monte carlo ss
what did it say gives a code and possible causes
3/21/2015 3:15:59 PM • Chevrolet... • Answered on Mar 21, 2015
07 CADILLAC CTS 3.6L P2195, P2197 CODES
P2195 - O2 Sensor Signal Stuck Lean Bank 1 Sensor 1, P2197 - O2 Sensor Signal Biased/Stuck Lean Bank 2 Sensor Sounds like a O2 sensors have a problem. Auto-Zone will check these codes for you for free.
3/21/2015 3:13:09 PM • Chevrolet... • Answered on Mar 21, 2015
2001 Suburban 1500 Heater/AC Control h71379052g roof mounted auxiliary, Passenger Side Rear, Manual temp control; roof mounted auxiliary, front, Manual temp control, w/sunroof San Francisco, California Logo
1 questions posted
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Chevrolet Vehicle Parts & Accessories
Most Popular Question
heater in 2001 chevy suburban wont blow
  • Vehicle Parts & Accessories
