20 Most Recent
JVC KD-LX30 CD Player Questions & Answers
Jvc kd lx30 lit up
You might want to check your speakers and speaker wires for shorts and/or grounds.
What makes a fuse blow after being on for about 15
Hi Bill,
Either a short or too small a fuse.
Many fuses are what they call, 'Slo-Blo'. they are designed to take high current for a few seconds before blowing. This prevents normal power surges from blowing the fuses.
If this is happing every time you replace the fuse, something is wrong internally that requires attention.
Remember, the fuse blows to protect the equipment. The next step is to find out what is making the fuse blow.
If it's under warranty, don't open it up. just exchange it.
As for the reason it's blowing, you would need to post all the symptoms.
Best regards
Mike
Unit won't read CD
The thing with Head Units is unless you take it to a guy that specialises in electronics to give the full problem, it's better to replace the unit. Also repair might cost a fortune. Can you get warranty?
My JVC-SD5 lights up, plays Music, but the lid won't open, any suggestions?
It seems like you're facing a little hiccup with your JVC-SD5. There's some troubleshooting ideas...
Firstly, make sure the CD player is powered off and unplugged from the electrical outlet. Safety first, right?
Now, take a good look around the edges of the CD lid. Sometimes, dust or debris can accumulate and prevent it from opening smoothly. Grab a soft, lint-free cloth and gently wipe the edges of the lid. Make sure to remove any obstacles that might be blocking it.
If that doesn't do the trick, let's try a little trick called the "manual release." Look for a small, pin-sized hole near the CD tray. It's usually located either on the front panel or underneath the CD player. Take a paperclip or a small, pointy object and insert it into that hole. Apply gentle pressure to trigger the manual release mechanism. This should pop open the lid, giving you access to your beloved CDs.
Once the lid is open, inspect the CD tray and the surrounding area for any visible signs of damage or obstructions. If everything looks fine, try closing and reopening the lid a few times to see if it starts functioning properly. Sometimes, a little exercise can go a long way in resolving minor glitches.
I hope these suggestions help you get your JVC-SD5 back in action and free you from that unwanted station! If you have any more questions or need further assistance, feel free to ask. Good luck!
My JVC stereo 6020 not making noise
i kindly recommend that you check volume level is not set to mute.Also,ensure that the stereo is properly connected to the speaker.check if the speaker are working
How to reset the clock on a JVC pc-110 boom box 1994 model?
To reset the clock on a JVC PC-110 boombox from 1994, follow these steps:
- Press the Clock Set button, located on the top of the boombox, to enter clock setting mode.
- Press and hold the Clock Set button until the hour digits on the display start flashing.
- Use the Fast Forward and Rewind buttons to adjust the hour to the correct time.
- Press the Clock Set button again to move to the minute digits. The minute digits will start flashing.
- Use the Fast Forward and Rewind buttons to adjust the minute to the correct time.
- Press the Clock Set button one final time to exit clock setting mode and save the new time.
Your JVC PC-110 boombox should now display the correct time.
How to reset password for jvc kw-v850bt
The process for resetting the password on a JVC KW-V850BT car stereo may vary depending on the specific model and software version. Here are some general steps you can try to reset the password on the JVC KW-V850BT:
- Disconnect the battery: Disconnect the battery of your car for at least 30 seconds, then reconnect it. This will reset the car stereo to its default settings.
- Press the reset button: If your JVC KW-V850BT has a reset button, press it and hold it for a few seconds until the unit restarts. This should reset the password to the default setting.
- Check the manual: Refer to the manual of your JVC KW-V850BT to see if there are any specific instructions for resetting the password.
- Contact the manufacturer: If you are still unable to reset the password, contact JVC customer support for further assistance.
It's worth noting that depending on the model and software version, the option to reset the password may not be available. In that case, you would have to contact the manufacturer for further assistance.
