20 Most Recent Akai ks-808 professional karaoke system with speaker pe Questions & Answers
0answers
Akai rmp3 recording tutorials
3/24/2023 5:57:06 PM • Akai Audio... • Answered on Mar 24, 2023
Akai home theater remote control ss4100
I.have.akai.hometneater.it.is.on.but.it.is.in.standby.mode.so.i.remote
12/17/2021 11:04:25 AM • Akai Audio... • Answered on Dec 17, 2021
Akai GX77 reel to reel tape recorder wont record
Check the bias oscillator is running. If you cannot, agree with the seller that they will cover the cost of repair at an authorised Akai service department or a trusted experienced repair person. They are worth up to £380 in good condition and fully working.
7/1/2021 6:51:33 AM • Akai Audio... • Answered on Jul 01, 2021
Model GX-255. Why doesn't it play stereo?
I am unfamiliar with the model even though I always wanted one... Playing stereo needs two working channels, any mono/stereo switch moved to stereo, any channel balance/volume controls appropriately adjusted and most importantly the source material must be stereo - in the case of taped material it must have been recorded in stereo in order to replay in stereo...
12/31/2020 6:43:22 PM • Akai Audio... • Answered on Dec 31, 2020
Model X-1800 SD amplifier. Why does it blow the main fuse?
You can't. You need the experience and lots of test equipment. Take it to an audio engineer.
12/31/2020 5:05:34 AM • Akai Audio... • Answered on Dec 31, 2020
2answers
Why do i hear crosstalk on my akai gx-230d tape deck?
Head alignment should be checked
12/1/2020 4:53:59 AM • Akai Audio... • Answered on Dec 01, 2020
2answers
Channels fade in and out when recording on r2r
When experiencing sound quality issues with any reel to reel deck, the very first thing to check is just how clean the tape transport system and tape heads are. Thoroughly clean all heads, including the erase head, and all tape transport parts, i.e., the capstan and pinch roller, and the reel drive wheels or belts. The other possibility is that the tape-to-head tension is too loose. This is a fine-value adjustment--too little tension results in your problem; too high tape tension results in drastically-shortened tape life or tape breakage. If you adjust it yourself, do so in tiny increments until the problem just goes away...then add just a hair more tension. It's like oil filter change instructions, "tighten filter to 1/4 turn beyond hand tight only". It only takes the tension being a tiny bit too tight to wear out or break your tapes.
12/27/2018 4:16:00 AM • Akai Audio... • Answered on Dec 27, 2018
Speed control not working correctly Akai GX 280D-SS reel to reel
Try using a tape deck cleaning solution on the pinch roller and capstan, as well as the rubber-rimmed wheels or rubber belts that operate each reel. Dirty capstan/pinch rollers will cause 'wobbly' sound; dirty reel drive rollers or belts will cause poor speed control, also resulting in funky sound. Keep in mind that if you clean everything and the problem persists, you will need to find replacement drive wheels or belts. Sometimes they are just too worn to work properly even if they are kept very clean. Wheels develop thousands of tiny age cracks, and belts typically stretch beyond the tensioner's ability to remove the slack, or they just get too old to work no matter what you try. If you clean the belts, be sure to clean the grooves on the back of the reel hubs where the belts go. If they are too dirty, you get the same problem.
12/27/2018 4:07:27 AM • Akai Audio... • Answered on Dec 27, 2018
I have an Akai HX M630W tape deck. Would anyone know a way of connecting the output from the ribbon cable connector to a computer/amplifier. (No longer have the Akai amp).
Look for a schematic for the unit online. There are a few website services which have obtained and catalogued vintage equipment owner and service manuals. Some of these websites offer the manuals in download form free, some actually mail you an original or reproduction on-paper manual for a fee, and some charge for anything you are looking for. The ribbon cable typically carries the tape head output signals to the preamp input stage of the Akai amplifier. Most ribbon cables, the wires are all the same color, although there may be one colored red indicating that it is the power supply wire. Good luck in your search!
12/27/2018 4:00:37 AM • Akai Audio... • Answered on Dec 27, 2018
Akai four track reel to reel won't record though vu meters say it is.
The vu meters only show that there is an input signal. The meters do not mean the deck is actually recording. If the deck will play a previously-recorded tape, how well does it sound? if the sound quality is muffled or very low, the play-back heads are dirty. If the playback heads are dirty, then the erase and record heads are too. In the tape path, the direction your tape moves from supply reel to takeup reel determines which heads are in which order. Most R-to-R decks play from left reel to right reel. The magnetic heads are in this order, with the the arrow indicating tape transport direction: Supply Reel moves tape across > Erase head first, then across > Record head second, then across > Playback head. Some machines use the same head for record and playback, but no machine uses the erase head for anything but erasing pre-recorded material on the tape. First, using tape recorder head cleaner or rubbing alcohol, clean the erase head (the first one the tape moves across) thoroughly with a Q-tip. If the heads are VERY dirty, use a pencil eraser AND the Q-tip. If this head is not clean, it will either not completely or not at all erase the material already on the tape. If the tape isn't erased, you either will get your new recording laid over the top of the existing one and it will sound like gibberish, or the new recording will not be recorded at all, and the original recording is all you will hear. Next, clean the second head the tape passes over. Usually this is the record head. If it is dirty, it will not record clearly or at all the material you are trying to record. Last, if there is a third head (most decks have this), clean it thoroughly as well. This is the playback head, and if it is dirty enough, you will hear nothing, although your new recording may very well have been laid down on the tape. Always clean all tape heads at the same time; in other words, don't just clean one head and not the rest of them. Clean all tape deck heads AS WELL AS the capstan (skinny metal pin that rotates) and pinch roller (the rubber wheel that 'pinches' the tape between itself and the rotating metal pin) thoroughly, rethread your tape through the head array, capstan, and pinch roller onto the takeup reel, and see what happens. If everything is clean and you still don't get any playback of your recording but you do get playback of pre-recorded tapes, then the problem is in the record circuit, and can be anything from faulty input stages to a bad head--deck heads DO go bad, although not often. If this is what happens, you have to take the unit in for repair by a qualified technician.
12/27/2018 3:54:01 AM • Akai Audio... • Answered on Dec 27, 2018
Akai ks-808 professional karaoke system with speaker pe Logo
3 questions posted
Top Akai Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry
ADMIN Eric
ADMIN Eric
Are you an Akai Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Akai Audio Players & Recorders
Most Popular Question
screen tftit not coming akia ks 808 fix
  • Audio Players & Recorders
