20 Most Recent Sea-Doo US Seadoo sea doo cdi ignition computer module 96 xp, gtx, gsx 787cc engine Questions & Answers
96 seaboo will not go full speed in water, but
carbs need cleaning and check the pulse jet that squirts fuel on set off , fuel pump diaphrams ok ?
7/8/2014 2:05:45 PM • Sea-Doo US... • Answered on Jul 08, 2014
Help!! '97 Seadoo GTI, just had the carburetor
Sounds like you might have the rotary valve in the wrong position. Also you are going to need to replace your fuel lines and check the fuel petcock for any blockage. Lastly, when u rebuilt this carb did you check the tiny fuel filter behind the pump body?
10/23/2013 7:45:38 AM • Sea-Doo US... • Answered on Oct 23, 2013
3answers
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM • Boating • Answered on Dec 05, 2023
4answers
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin Cruisers are 20-40 feet. There are of course larger Yachts that can get to over 100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM • Boating • Answered on Nov 15, 2023
Diesel Boat motor cuts out under increased revs
I would clean the fuel filters and empty the water retainer filter then do some testing.
11/7/2023 9:11:35 AM • Boating • Answered on Nov 07, 2023
2017 Tracker 17.5 ft. boat. How can I remove batteries from it please.
Question edited for clarity. Question moved to Boating. Hello Anonymous Harriet :>D You will have two or possibly 3 batteries. Usually a large car type starting battery for starting the engine. Then two Deep Cycle Gel Batteries, one for the marine electronics, fish finder etc, and another that powers the front bow mounted Trolling motor. You will find them in the deck lockers. Open them, release any tie downs, undo the cables and lift them out for Winter storage. I keep mine in my garage and I put them on a battery minder for 24 hours once a month. I have the Battery Tender Junior, and I put them on a 6 amp car charger before the season starts. https://www.google.com/search?q=Battery+Tender https://www.google.com/search?q=2017+tracker+175+remove+battery The information you gave is is merely the year of manufacture, the maker and the length. They all have model numbers. That would be the key to searching for a manual online. https://www.jdpower.com/boats/2017/tracker-marine/pro-guide-v-175-wt__/32067137/specs and https://www.bbcboards.net/showthread.php?t=969900 ..
11/4/2023 10:54:05 PM • Boating • Answered on Nov 04, 2023
2017 Tracker 175 boat. Owners manual for it please?
Question edited for clarity. Question moved from Cars and Trucks to Boating. They don't list Manuals, but they should link you to one in their archive.
TRACKER Boats Learning Center
Tracker Boats https://www.trackerboats.com > learning-center PRO GUIDE V-175 WT · TARGA V-18 WT · TARGA V-19 WT · Jon Boats · GRIZZLY 1648 JON ... Owners. Warranty Information · Warranty Claim · Warranty Transfer · Order ...
11/4/2023 10:33:35 PM • Boating • Answered on Nov 04, 2023
Overheating on 150 Susuki outboard motor.
check water flow pump fail -corrosion--debris blockage---check fluids--gear oil etc
10/18/2023 12:53:27 AM • Boating • Answered on Oct 18, 2023
Yanmar 4BY2 with 1000 hours overheats when run above 2000 rpm - this is new, she cruises at 3500 rpm all day when running OK. Loses 1 gal water in 5 min at 3200 rpm. No visible leaks, smoke.
Commonly caused by clogged air filter. Also suspect buildup in exhaust mixing elbow. Smoke will build up carbon deposits over time and clog them. What color is the smoke? unburnt fuel will smoke and cause heat. Could be a fuel pump or dirty/bad injector not atomizing fuel correctly. If smoke is steam.... If there isn't proper flow or there is air in raw water system, the air hits heat exchanger and immediately turns to steam. Will result in overheating.
10/17/2023 10:48:57 PM • Boating • Answered on Oct 17, 2023
My 40 hp mer user.40elptefi dies if not connected to battery
It's electronic fuel injection so it needs power to run. Mercury is usually a yellow wire from stator that goes to a voltage regulator that charges battery when running. Good luck!!
10/17/2023 10:35:57 PM • Boating • Answered on Oct 17, 2023
I have a 37 ft Cruisers with T-D6-370-
def check fuel filters and air filters. Is it smoking when powered up? If so, what color is smoke?
10/17/2023 10:31:15 PM • Boating • Answered on Oct 17, 2023
Bilge pump and float wiring 242 cr
check continuity on float switch to assure it's working. image 10-17-23 at 18.24-undefined-undefined-1.jpeg do you have it wired like this?
10/17/2023 10:25:48 PM • Boating • Answered on Oct 17, 2023
2answers
What is the most expensive yacht in the world?
Off-course There are so many companies who are offering expensive yacht charter for rent in and around Europe. I suggest you to enter Kavas is the only yacht chartering company in Greece with over 25 years of experience in our industry. Kavas is offering all range from reasonable to luxury yacht services in Athens, Kos Island and Lefkas Island. For more details visit Bareboat or Crewed Yacht Charters in Greece
10/13/2023 4:52:02 PM • Boating • Answered on Oct 13, 2023
I have a ps 24 wagner prospray the unit is not working an it said check transducer...what is that????
page 15 of instructions. here is a link to manual https://www.manualslib.com/manual/907399/Wagner-Prospray-24.html?page=15#manual
9/12/2023 1:36:10 PM • Boating • Answered on Sep 12, 2023
3answers
I need to find a replacement remote control troll for my osim imedic 380
they are obsolete and not made anymore. best get a new machine or use it manually.
8/31/2023 10:44:56 PM • Boating • Answered on Aug 31, 2023
Looking for a wiring diagram for a 1978 Caravelle Bow Rider Boat with a 305 Mercruiser in & out
http://boatspecs.iboats.com/Caravelle_Boats__CX__1978/bp/34br1078s732y Service manual
MERCRUISER 305 CID (5.0L) SERVICE MANUAL Pdf ...
ManualsLib https://www.manualslib.com > ... > 305 CID (5.0L) View and Download MerCruiser 305 CID (5.0L) service manual online. 305 CID (5.0L) engine pdf manual download. Also for: 350 cid (5.7l), 5.0 mpi. ‎Valve Adjustment · ‎Ignition Timing · ‎Fluid Capacities · ‎Transmission Fluid
MerCruiser Service Manual Free Download PDF
downloadboatmanuals.com https://www.downloadboatmanuals.com > mercury MerCruiser Service Manual Free Download PDF. On this page you can free download service & repair manuals for such sterndrive engines as MerCruiser. ..
8/7/2023 6:51:51 PM • Boating • Answered on Aug 07, 2023
1991 Rinker 186 Captiva I/O 4.3 mercruiser what size freeze plugs for exhaust
part #18-5961-9 Freeze Plug - 1 5/8" Bronze for Mercruiser Stern Drives. Check out this video too.... https://www.youtube.com/watch?v=yp-iO6bNik0 Best to you.
7/31/2023 10:32:29 PM • Boating • Answered on Jul 31, 2023
2000 Reinell 19 foot open bow runabout. How to open engine cover hatch when the strap is unavailable?
Is it locked or does the strap just help to lift it like on a Bayliner? Take a piece or 2" x 1" timber and cut a wedge on the end. Slip it into the joining surfaces, push and lift. Not much available on it. https://www.google.com/search?q=2000+Reinell+19+foot+open+engine+cover ..
7/29/2023 5:25:24 PM • Boating • Answered on Jul 29, 2023
Where can i get specs for cb radio navstar kr-113 a
Looking for a manual for a navstar kr 113 radio and what tipe of atenna will be the best for radio
7/24/2023 10:44:46 PM • Boating • Answered on Jul 24, 2023
Sea-Doo US Seadoo sea doo cdi ignition computer module 96 xp, gtx, gsx 787cc engine Logo
1 questions posted
Top Sea-Doo US Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Sea-Doo US Boating Expert? Answer questions, earn points and help others
View Most Popular
Sea-Doo US Boating
  • Sea-Doo US Boating
Most Popular Question
  • Boating
