20 Most Recent
Sanyo PLCXU355 LCD Projector Questions & Answers
Red warning light
follow this steps and fix it. God bless you
Secure the lamp cover and the air filter cover of the
projector body if the projector does not power on. Ensure that the power
cable is firmly connected to the projector and an active power plug. If
the projector was turned off and then on quickly--let it sit for 90
seconds before trying to turn it on.
Replace the projection lamp if the projector will not power
on or if the lamp indicator is flashing. Turn off the projector and let
it sit for at least 30 minutes. Locate the lamp cover and remove or
loosen the lamp cover with a screwdriver. Carefully remove the
projection lamp from the projector housing using the handle, if
available.
Place the new projection lamp into the projector housing and
secure it to the projector. Replace the lamp cover and reset the lamp
timer. Power on the projector to ensure the new lamp is working
correctly.
Remove the projector from the enclosed area to allow air
circulation if it constantly overheats. Place the projector into an open
area and make sure there is no blockage for the ventilation holes.
Unplug the projector for at least 45 minutes to allow it to soft reset.
5
Clean the air filter to allow the projector better air
circulation. Turn off the projector and unplug it from the outlet.
Remove the air filter cover and use a vacuum to remove dust from the
area. If the filter is unable to be cleaned correctly or is damaged,
then replace it. Pull the air filter from the projector and place the
new one in the now empty slot. Close and secure the air filter cover.
How can i download divers for sanyo xu 101 projector
To download drivers for the Sanyo XU 101 projector, you will need to visit the Sanyo support website. Here are the steps:
- Go to the Sanyo support website by typing "Sanyo support" into your search engine and clicking on the first link.
- Once on the Sanyo support website, click on the "Projectors" category.
- Select your projector model, which in this case is the XU 101.
- Click on the "Downloads" tab, where you can find the available drivers and software for your projector.
- Look for the driver that you need and click on the download link.
- Follow the instructions to download and install the driver.
If you have any issues with the download or installation process, you can contact Sanyo customer support for further assistance.
My Sanyo dp42481 pic is upside down and mirrored how do I fix it
If your Sanyo DP42481 picture is upside down and mirrored, you can try adjusting the settings on the TV. You can do this by going to the Picture Settings menu and selecting the "Picture Orientation" option. From there, you can select the "Normal" option to reset the picture orientation. If the problem persists, you may need to contact the manufacturer for assistance.
Sanyo AWD-AQ4000(S) U3 error code
The "U3" error code on a Sanyo AWD-AQ4000(S) air conditioner indicates that there is a problem with the unit's compressor. This could be caused by a variety of issues, such as a faulty compressor, a malfunctioning control board, or a refrigerant leak.
To solve this issue, I recommend the following steps:
- Make sure that the air conditioner is properly plugged in and receiving power.
- Check for any visible damage to the unit, such as bent fins or loose wires.
- Check the air filter and clean or replace it if it is dirty.
- Check the outdoor unit for any visible damage or debris that may be blocking the airflow.
- Check the refrigerant levels and make sure they are at the proper level.
If those does not work, it may be time to check with a professional!
Sanyo PLC-XU305 Projector
Being an old projector and possibly it has an old lamp fitted.
The lamp as it ages produces more heat. The fans as they age unless cleaned regularly. This build up of heat damages firstly the blue LCD imager and then the red.
Nothing can be done about that except replace the LCD imagers.
As a Sanyo Authorised service department, we used to charge them out at £1031 plus fitting.
