m
manos manolaki Posted on Mar 06, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sanyo PLC-XU305 Projector
I own a Sanyo PLC-XU305 Projector, the colours are not good, I tried to fix them but nothing, the red is not red but a lot diferent, what do I have to do to fix the problem?? thanks a lot
ADMIN Eric
Level 3:
Top Expert:
  • Sanyo Master 39,345 Answers
  • Posted on Mar 06, 2022
ADMIN Eric
Sanyo Master
Level 3:
Top Expert:
Answers
39345
Questions
0
Helped
794436
Points
588034
Being an old projector and possibly it has an old lamp fitted.
The lamp as it ages produces more heat. The fans as they age unless cleaned regularly. This build up of heat damages firstly the blue LCD imager and then the red.
Nothing can be done about that except replace the LCD imagers.
As a Sanyo Authorised service department, we used to charge them out at £1031 plus fitting.
2helpful
I hv Sanyo PLC-SU07N Projector - the image is blue
I have a possible solution however it may not be THE solution your after, you'll probably be able to tell very quickly if it isn't, this will only apply if you are using either a component video signal or a PC/laptop signal to send to the projector.
If you are using a laptop or desktop to hook up your projector, I would try first of all double checking that it's correctly plugged in, and if you still have no luck try a different cable.
It's likely to be the cable because when the signal goes down the cable it's split into 5 different signals. 3 of these are the colour information for Red, Green and Blue. Depending on what you mean by 'image is blue', it could mean that your either not getting the information for Red, or your not getting the information for Red AND Green. If you want to test this, open up microsoft paint while connected to the projector and create 3 boxes, then fill 1 completely red, 1 completely green and one completely blue. If you are missing the information to any of these colours then that colour will appear black on the projector screen.
In component video the signal is split down 3 cables (rather than 5) and 2 are colours (rather than 3)... Red and Blue. Check that the cable running red (Usually labelled Pr on the DVD and projector) is completely plugged in (some of these are really tight, but it's important that it goes all the way) and also that you have plugged into the correct slot, for instance that you have plugged into Pr and not the right Audio channel, both of which are coloured red.
If you are still not having any luck then I would suggest using a computer monitor or a television (depending on what type of signal your sending it) to test the projector. Plug it in instead of the projector and if it works then the issue lies with the projector and I have at least narrowed it down for you.
Hope this has been helpful.
Plc-xu105 will not restart. red on, no fans
SAYA MEMPUNYAI SANYO PLC XU105 , JIKA DIHIDUPKAN POWER LAMP MENYALA HIJAU BEBERAPA DETIK KEMUDIAN LAMPU WARNING LAMP MENYALA, KIRA KIRA KERUSAKANNYA DIMANA YA..? TOLONG YA SOLUSINYA..THKX
Problem sanyo projector having yellow tint PLCXP57L
Colour settings
Here's a service manual it has the right settings. Hopefully it resolves the issue..Click on the link below to download.
http://www.mediafire.com/?mnty4nwymym
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Yellow band on the edge of screen
Hi chucri
This is most definitely not a lamp problem.
If a yellow colour in either stripes or blotches occur it is a blue LCD polarizer that needs replacement.
3helpful
2answers
Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
3answers
Sanyo Pro Xtrax
You need to change th bulb. It's damaged
Top Sanyo Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Rob Hill
Rob Hill
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
