20 Most Recent
SonicWALL PRO 1260 SonicOS Enhanced Firmware (01SSC5876) Questions & Answers
I forget my sonicwall admin password how will
If the SonicWALL's admin password is lost, there is no backdoor or other
mechanism to bypass the administrator login. Please note that prefs
files do not contain the admin name and password. So if you reset the
firmware and import a current prefs file, you can gain access using the
default login credentials ('admin' & 'password'). Without a current
prefs file, you must reset the firmware and configure from scratch.
For
models running SonicOS (Enhanced or Standard), you can reboot to
factory defaults. This resets all settings including the admin name,
password and LAN IP address. Import the current prefs file. The
configuration is restored and use the defaults 'admin' and 'password' to
login.
For models running Firmware 6.X, you must reset the
firmware (wipe and upload using the reset procedure). Import the current
prefs file. The configuration is restored and use the defaults 'admin'
and 'password' to login. The 'Reset to Factory Defaults' button does not
reset the admin name, password or LAN IP address for these models
Strange noise
Sounds (pun intended) like one of the cooling-fans has worn-out bearings, and is "screeching", just before it totally freezes-up, and dies, and causes your SonicWall to overheat.
7/29/2014 3:53:48 AM •
SonicWALL...
Answered
on Jul 29, 2014
UPNP over sonicwall
For "security" reasons, you should not all UPNP traffic from "outside" of your network to enter your "internal" network. Block it.
7/29/2014 2:58:47 AM •
SonicWALL...
Answered
on Jul 29, 2014
Remove pc performer from my computer
Hi you can remove the PC Perfomer using the software Ccleaner.
CCleaner 4 09 4471
select tools and uninstall the PC Performer, if it doesn't uninstall then select delete entry. Also Ccleaner makes your computer faster by removing temporary files/cleaning registry. Hope this helps.
5/30/2014 6:08:17 AM •
SonicWALL...
Answered
on May 30, 2014
Hack the sonic wall
Hacking is a broad term and there are many attack vectors which you can use. If you do not truly understand that then you will not be cracking a firewall. You need a method of attack, recon it and search the vulnerabilities.
4/28/2014 7:07:17 PM •
SonicWALL...
Answered
on Apr 28, 2014
Get bsnl internet settings sony xperia
The high-level answer is to get the login parameters and internal IP for the Sonicwall, get the Internet parameters for your new ISP, and then log into the Sonicwall device, go to Networking-> Interfaces, and configure the WAN adapter with those settings.
1/31/2014 2:27:29 PM •
SonicWALL...
Answered
on Jan 31, 2014
