Try 192.168.0.1 - which is the default IP address. If this will not work, you will need to reset the router. Use 'ipconfig' command from your computer to see what the router ip address is reporting.
Here is a reference to help you: http://www.howtoquick.net/2012/10/how-to-set-wifi-password-on-mf30-global-mobile-hotspot-pldt-negosyo-boost-modem.html
Opening up the GUI:
1) Open up any browser
2) Put 192.168.1.254 in as the URL and hit enter
3) Search for wireless settings
4) Change Network Access key
5) If that's greyed out then you might have to change the security settings to WPA-PSK
Note: If it asks you the for the Network Device Code, that can be on the sticker on the side of the router.
If you forget the password, you need to reset the device to the factory default settings. In that case, all configuration settings of the device are lost then you need to reconfigure the router, To reset the device to factory default settings, follow the instructions from this link,http://global.dlink.com.sg/site_support/DSL-2640B/Manual/DSL-2640B_manual_v2.pdf
Hi, try to remove your current connectivity setup then refresh new list for wifi connection, there you can have it pop up the access credentials again.If not access the wifi setting of your network to check the current password.
You have been prompted for the login password and received the following message: “Login Password isinvalid”.• Re-enter the correct password and press enter. Remember that the password is case-sensitive. Check that youare entering admin in lowercase and that the Caps key is not active.• If you have forgotten the password, you must reset the login password. Refer to the User Guide, ChangingConfiguration Switches, and perform the following procedure:1. Move switches 5 and 6 down.2. Type login <newpasswd>. Password checking is overridden.3. Move switches 5 and 6 up.4. Complete any configuration update that caused the prompt for login.5. Change your login password to a new password.6. Store the configuration and reboot the router.Note: If you have not reset switches 5 and 6 to the up position and have rebooted, this will place the router inmaintenance mode. Set switches 5 and 6 up and turn the power off and www.alliedtelesyneurope.com/media/.../manuals/rg624-34_um_a.pdf
