20 Most Recent
Yamaha CDC-655 CD Player Questions & Answers
Pwr. on but won't play cd,
The lazer is not reading the info off the disc any more, It is costly to have them (Replaced) $180 to $250.
Tray slides in, but then
The broken CD may have ripped the laser lens off. If that has happened, you need a new CD player.
I need a new drive
If you know the size (Diameter, Shape & Cross Section) of it then your best option is probably eBay.
Yamaha CDC-80 drawer won't open
Hello
There are two possiblities for this fault. The first one is, loading belt broken, or loose. The second one is, loading motor fails to rotate. it may be due to voltage related problem, that is, no voltage comes to it from the circuit board, or it has failed to rotate due to some internal fault itself.
You just open and inspect for these troubles Ok.
CDC-655 was put in storage (in orig box) and
This seems to be a "Dust on Lens" problem. No issues... It happens when you keep your CD/DVD players unattended for a long period of time. Even if packed well enough, dust/moisture does tend to gather on the lens and cause this type of an irritating problem.
If you have a lens cleaning CD (if not, go buy one) then just insert it and let it spin regardless of whether or not it reads it. The spinning action will clean off any finely deposited dust particles on the lens. Repeat th process till the Lens Cleaner CD starts playing its audio. If this happens then all your other CDs should read. One more thing, make sure that the motor is indeed spinning. How can you know???
1. Buy listening carefully for a whirring sound the moment you put in your CD/DVD
2. By feeling for minor vibrations on the front panel (CD tray front cover)
3. Putting in a CD/DVD with a label straight as you can read it and see if it comes out differently on ejecting it. I hope you understand what I mean...
If this doesn't then it could be a blown lens circuit or a dead drive motor. In that case your player needs to be taken to a service center.
Hope it answers most of your query. Good luck.
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool.
the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny).
