20 Most Recent
Keurig K75 Black Platinum Coffee Maker w 12 K-cups - Replaces -B7 Questions & Answers
Need to descale k75.
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste
Keurig k155 touch screen blank
If the touch screen of your Keurig K155 brewer is blank, here are some steps you can try to troubleshoot the issue:
- Check the power supply: Make sure the brewer is properly plugged in and the outlet is working. Try unplugging and plugging the brewer back in to reset it.
- Clean the touch screen: Use a soft, damp cloth to clean the touch screen, as dirt and debris can interfere with its function.
- Perform a hard reset: Unplug the brewer from the power source and remove the water reservoir. Press and hold the power button for 5 seconds, then release it. Wait for 2 minutes, then plug the brewer back in and turn it on. Reattach the water reservoir and try using the touch screen again.
- Contact customer support: If none of the above steps work, you may need to contact Keurig customer support for further assistance. They may be able to offer additional troubleshooting steps or provide repair options if needed.
Keurig shuts off after i push the brew button?
Some of the most likely reasons by which Keurig keeps shutting off while brewing includes:
Machines require Descaling or cleaning.
The bottom of the k-cup is not punctured.
Misaligned magnet in water Reservoir
In this
article , all these reasons are discussed in detail, which might help you
Cusinart keurig coffee maker not working
What's With the Cuisinart SS-10 "EEO" Message?
A few reports surfaced that gave me cause for concern: A number of people were getting "eeo" error messages in the menu window. What panned out is that these were inoperable. When there were error messages like "add water" and "descale" that were out of line with the consumer's actions, the simple act of unplugging and waiting a few minutes then re-plugging it back seemed to take care of it
Also as per the manual, pressing and holding the Hot Water and Rinse buttons simultaneously will reset the machine and get rid of the nuisance "Descale" message that has irked some owners.
But as I found out later -The user manual under the Troubleshooting section says if you get "eeo" in the display window to "Call customer support" along with the number, so it is a whole other ball game - a sensory defect, and clearly a sign of a dud.
And this on Just Answer regarding a 2 month old machine.
Thanks for your question
I'm Martyn, welcome to JA.
This Error has been a reported issue with some models... a faulty tube is suspected
As it is only 2 months old, Warranty issues need to be dealt with by the store where the appliance was bought in the first instance...
DO NOT attempt any repair or you WILL VOID your Warranty
Call the supplier first, and they will deal or refer you
I hope I've been able to provide you with the information you were seeking.
If you are happy with my service, your positive rating, before we finish up here, is most welcome.
Need more help about this issue ? Please let me know.
And then I found this in a video.
Press and Hold the Hot Water and Rinse buttons will reset the machine.
And finally from the manual, "Call Customer Support".
https://www.manualslib.com/manual/1078422/Cuisinart-Ss-10.html?page=20
Please let me know how you get on as I haven't come across this error before.
Model # D513,572 Keurig coffee machine how do I get a manual?
This should be it
Keurig B60 Owner's Manual (Page 34 of 35) ' ManualsLib
https://www.manualslib.com > ... > Owner's manual
CLICK, CALL OR SHOP I www.keurig.com I. For Household Use Only. Covered by U.S. Patent Numbers 7,398,726, 7,165,488,. 7,347,138, D513,572, 7,377,162, ...
KEURIG LID HANDLE WILL NOT STAY UP WHEN REPLACING A K CUP
Hi Julia, I have a problem answering your question as I do not know what module you have. These typically have a life span of 3 to 5 years, if it has reached that age or older consider replacing it. The most inexpensive option is just to hold the handle when replacing the cup.
New Keurig B140 will not pump or prime
On the water reservoir there is a little black disk, a magnet, I think... If that is not against the machine it will display the prime error. Empty the water from the reservoir and tilt it so that the disk is against the machine. Place the reservoir empty back on the machine and fill it with water carefully as not to move the disk. When the water level gets to the correct position, the prime error will go away.
