20 Most Recent
Brother VX1435 Mechanical Sewing Machine Questions & Answers
My needle will go up but not back down why?
it's possible that there could be something wrong with the needle bar, and if the sewing machine has any electronics to it, that could also be a problem, if the problem continues, it would be a good idea to have the machine checked.
My sewing machine runs but
Is your bobbin winder button pushed all the way to the left? Sometimes, it will stick and not let your machine run. Move it back and forth a few times, then select a straight stitch and long length. Good luck
Brother VX1435, needle won't move
some machines when the bobbin winder is engaged will not sew, do youhave to disengage the center wheel in the handwheel to wind a bobbin?or do you have to just move the bobbin winder spindle to the right to wind the bobbin?do you have a manual for the machine?
After hitting a pin with
try a new needle first if that dont fix it then you have knocked the "timeing out" a repair job?
