20 Most Recent Philips GC 7220 Iron with Auto Shutoff Questions & Answers
I just cleaned my iron using the calc button as per intructions, when i plugged it back in to the socket it tripped a switch, has water gotten into the iron somehow? is there any way to save the iron/
check for a short wiring in the terminal of the filament.make sure the terminal is dry no water leak.
11/26/2012 11:55:59 AM • Philips GC 7220... • Answered on Nov 26, 2012
0answers
2answers
Steam generator iron spitting out dirty water
Try vinegar. Unplug from power, fill and let soak for a couple hours. Then rinse and see.
1/29/2019 10:12:17 PM • Philips Irons • Answered on Jan 29, 2019
Have philips perfectcare gc 9240. Heats up is on. But no steam? Has anyone had this problem. And is there a possibility if anyone has repaired what the fee was? Thank you, angela.
You should hear the boiler heat up the water. When you pull/push the trigger, a pump should be activated and steam should be released. If the pump is not working, it could be a defective capacitor acording to this article: https://lieven.kks36.be/2016/06/11/philips-perfectcare-aqua-does-not-pump-solved A spare capacitor should cost you no more than a few dollars, just find somebody with electronics/soldering repair skills.
12/16/2017 2:07:39 PM • Philips Irons • Answered on Dec 16, 2017
I purchased the Philips GC 7000 I want to know if the temperature can be adjusted
Because its a temperature controlled iron, I would say that it only gets to the temperature to create steam and no hotter.
4/27/2017 12:56:14 AM • Philips Irons • Answered on Apr 27, 2017
Philips GC 7220 Iron with Auto Shutoff Logo
Popular Tags
15 questions posted
Top Philips Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Philips Iron Expert? Answer questions, earn points and help others
View Most Popular
Philips Irons
  • Philips Irons
Most Popular Question
just cleaned iron using calc button as
  • Irons
