20 Most Recent
Meiko K76ET Dishwasher Questions & Answers
Meiko dv120.2 dishwasher info code 124. What does this mean and how is it fixed?
You should contact yourMEIKO Authorized Service AgentIF:
•The utensil washer encounters a problem but does not display
an error code, OR
•An error code appears that is not shown here, OR
•The listed action fails to correct the problem.
An Authorized Service Agency Listing was supplied with your
utensil washer. If you do not have the listing, call 1-800-868-3840
for assistance.
3/8/2023 8:36:31 AM •
Meiko...
Answered
on Mar 08, 2023
Meiko dish washer Temperature fault rinse error
If you are still experiencing the H0005 temperature fault alarm on your Meiko dishwasher after replacing the PT100 sensors, there may be a problem with the dishwasher's control panel or other internal components.
Some potential causes for this problem include:
- The control panel may be faulty. If the control panel is not functioning properly, it may not be able to read the temperature sensors correctly and generate the H0005 error.
- The wiring for the temperature sensors may be damaged or disconnected. Check the wiring to ensure it is secure and in good condition.
- The dishwasher's heating element or other internal components may be faulty. If the heating element or other components are not functioning properly, the dishwasher may not be able to maintain the correct temperature during the rinse cycle.
If you are unsure how to check for and address these potential causes, you may want to consult the user manual for your Meiko dishwasher or contact the manufacturer for assistance.
12/10/2022 3:56:51 AM •
Meiko...
Answered
on Dec 10, 2022
I have a Meiko hood type dishwashing machine DV80.2. The unit is not starting only displaying Err. 901
Error 901 indicates a communication problem between the CPU board and the double-stacked I/O board in the contactor box. These boards communicate via a CAN bus using an RJ45 / ethernet cable.
1. Check the communication cable (RJ45) to ensure it is operating.
2. Is there an LED lit up on the double-stacked I/O board? If not, then this is the reason for the 901 code. Check for DC voltage at the 3-pin connector on the left side of the I/O board. If voltage is present but no LED lit on the board, replace the I/O board. If there is no voltage, check the power supply board. The power supply board is the square board to the left of the I/O board.
3. Check for cockroaches or cockroach droppings in the RJ45 communication ports. Clean out if necessar with compressed air.
4. Check the CPU board located behind the front panel with buttons on it. Remove the plastic cover over the board. Is there an LED lit up on it? If not, check for voltage at the 4-pin plug. If there is 12V DC and no LED, the CPU board is the problem. If there is no DC voltage at the 4-pin plug, check the power supply board.
5. Check the DIP switches on the I/O board. Make sure only the number 1 DIP switch is turned on. The remainder should be off.
8/20/2022 3:25:45 AM •
Meiko...
Answered
on Aug 20, 2022
Meiko dishwasher. Do I have an eeprom problem?
sounds like it could be a defective cylinoid switch...this will not allow water to flow properly through the machine....this is located at the water connection....try replacing and reconnect water...good luck
9/13/2021 9:26:11 AM •
Meiko...
Answered
on Sep 13, 2021
Meiko dishwasher model 80.2 showing error 204 when water filling to the tank, give me the solutions..
This is straight from the repair manual.
204 Final rinse time Parameter 4 ... 30 s. 7 Duration of booster pump activation (running time limited by P306!!).
306 Maximum final rinse time Parameter 0 ... 30 sec. Maximum booster pump running time (rinse) (limit of P204)
Booster heater pump does not work Check power supply to power rinse pump. Check pump rotor and replace 203/204 pump if necessary. Check start capacitor and replace if necessary.
Hope this is of some help.
7/14/2019 2:43:56 AM •
Meiko...
Answered
on Jul 14, 2019
