20 Most Recent Meiko DV80.2 High Temp Door Type Dishwasher Questions & Answers
307 Wash tank level sensor defective (short circuit) Check connection, defective sensor, I/O board defective.
Per service manual.
Meiko DV80.2... | Answered on Oct 07, 2017
follow this steps and fix it. Merry Christmas
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
Main Control Module / Timer
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace main control module. this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Meiko DV80.2... | Answered on Dec 26, 2014
make this test and fix it. Merry Christmas.
Power Supply
The main power supply is the first thing to check. Also remove the toe kick and the cover on the power box and check the connections. Also check the 120 volts in p. box.
Hi - Limit Fuse
This will fail if your dishwasher overheats and occassionally with power surges. This is easy to check, inexpensive and a quick fix. Just check the terminals for continuity ( remember always remove one wire) if you have none replace the hi-limit fuse
Door Switch
This is the second place to look. Again an inexpensive easy fix. The power comes into the main power box and usually runs to the door switch next before entering the main control module. Replace the door switch if is faulty, use the Multimeter
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace the main control modul l/timer this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Motor
The motor may have failed. If the control illuminates on electronic versions the problem may be the motor. To check the motor refer to the tech sheet located behind the console cover on most models, this will sometimes have the ohm reading of the motor. Also check each lead to the metal housing of the motor to check for shorts in the motor. If you do not have the ohm reading specicifications, check for continuity if none replace the motor Make sure the the motor is having power 120v
Float Switch
If the float switch has failed or is stuck the dishwasher control may not respond. The float switch is easy to check and replace.
Meiko DV80.2... | Answered on Dec 19, 2013
Meiko ecostar 503 f error 907
Meiko... | Answered on Sep 13, 2019
This is straight from the repair manual.
204 Final rinse time Parameter 4 ... 30 s. 7 Duration of booster pump activation (running time limited by P306!!).
306 Maximum final rinse time Parameter 0 ... 30 sec. Maximum booster pump running time (rinse) (limit of P204)
Booster heater pump does not work Check power supply to power rinse pump. Check pump rotor and replace 203/204 pump if necessary. Check start capacitor and replace if necessary.
Hope this is of some help.
Meiko... | Answered on Jul 14, 2019
Hi , can you let me know serial number?
Meiko... | Answered on Feb 23, 2019
907 Error bus node code 7 see Err 901 2. Power supply (EW) defective.
917 Input/output model not compatible code 7 P236 code on I/O PCB incorrectly defined.
Straight from their manual. Sounds like some multiple issues.
Meiko... | Answered on Jan 23, 2019
Hi Coleen
Which machine do you use please ?
Regards,
Seb
Meiko... | Answered on Nov 07, 2018
Could be a defective fill valve or float valve
Meiko... | Answered on Jul 24, 2018
Meiko DV80.2 High Temp Door Type Dishwasher Logo
6 questions posted
Top Meiko Dishwashers Experts
jdthefixer
Marvin
Marvin
Dennis Boxerman
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Meiko Dishwashers
  • Meiko Dishwashers
Most Popular Question
meiko dv80 2 error 307
  • Dishwashers
