20 Most Recent Kenwood DNX6160 Car Video Player Questions & Answers
0answers
This has been a weird hookup from the onset. I
Hi gdossey574,
You must have the mute wire installed on the phone.
Refer to page 45 of your owner's guide to the section entitled "Muting audio volume upon reception of phone call". The note will explain the wire hook up. Unhook this wire.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
5/27/2011 6:45:50 PM • Kenwood DNX6160... • Answered on May 27, 2011
Installatoin Manual for Kenwood DNX 6160 for 1992
You can download the installation manual at
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Consumer/Manuals/dnx6960_Install.pdf
3/30/2011 6:06:31 PM • Kenwood DNX6160... • Answered on Mar 30, 2011
HI, I HAVE A DNX6160 AND HOOKED UP THE BACKUP WIRE
hi judging by your wirering it seems to be ok did you check to see iff there was power going to the camera or the camera could be faulty also check all power leads with metre if you have one if not get a 12volt bulb and connect you reverse wirering to it or check for breakage in wire going to camera its most likely a power fault ,or camera faulty goodluck
3/20/2011 10:11:49 AM • Kenwood DNX6160... • Answered on Mar 20, 2011
Can't use SMS with Iphone 4 and Kenwood DNX 6160
Apple and most other phone manufactuers do not support the SMS features. Contact Apple and request that they support it.
2/4/2011 4:15:21 AM • Kenwood DNX6160... • Answered on Feb 04, 2011
2answers
Gostaria de saber se é
please can you rephrase this question in English? I would love to help, but I don't understand this language in which you are using to communicate.
I would appreciate it, if you can respond in English.
I look forward to your reply.
Bye for now.
1/7/2011 3:35:13 PM • Kenwood DNX6160... • Answered on Jan 07, 2011
My kenwood dnx6160 shuts off when i roll my window
this is cause by the stereo overheating.
12/23/2010 10:23:29 PM • Kenwood DNX6160... • Answered on Dec 23, 2010
I just installed the 6160
go back to installer and demonstrate ,could be a incompatable issue with digital and analogue sound but without having a play myself its difficult to diagnose online.it might just be a plug not in properly on the back of the set ,as for the sms bluetooth operation it might just need a switch on the back of the set that needs switching on .Best advice is to return to fitter and ask politely and iam sure they will bend over backwards to get it all working prpoerly for you
10/2/2010 2:54:02 PM • Kenwood DNX6160... • Answered on Oct 02, 2010
My kenwood kdc-u2159b display call n no sound out
Me radio kdc2159b is displaying the ward call,how do i remove it
4/14/2024 10:44:35 AM • Kenwood Car... • Answered on Apr 14, 2024
Reset a Kenwood 8070 without a remote?
To reset a Kenwood 8070 receiver without a remote, you typically need to locate the reset button on the device itself. This button is often small and recessed, so you may need a paperclip or a similar tool to press it. Consult the user manual or look for the reset button near the power or input/output ports on the receiver. Once located, press and hold the reset button for a few seconds until you see the receiver reset. Keep in mind that this process may vary slightly depending on the specific model of the Kenwood 8070 receiver.
3/6/2024 3:50:24 AM • Kenwood Car... • Answered on Mar 06, 2024
KDC-138 CD PLAYER/RECEIVER. What does code E-004 indicate?
Kenwood KDC-138 Instruction Manual [Page 18]
ManualsLib https://www.manualslib.com > ... > Instruction manual If the "E-99". code does not disappear, consult your. nearest service center. IN (Blink):. The CD player section is not operating. properly. ? Reinsert the CD.
My Kenwood KDC-d301 is giving me a E-4 error message ...
JustAnswer https://www.justanswer.com > car-electronics Aug 9, 2010 - Hello, The issue is most likely that the laser lens in the CD player itself is dirty, and not the disc. It may have been initially caused by a ... 1 answer · Top answer: You need the Kenwood radio keys that came with the unit to slide it out of the dash. It sounds ... Missing: 138 ‎' Show results with: 138
I have a KDC 138. It is stuck on OCER and will not reset.
JustAnswer https://www.justanswer.com > car-electronics > 5lw8u-... Sep 27, 2011 - This actually is DCER - you have a blown speaker. The radio is sensing a ground on the speaker circuit. Check that and let me know. If you leave ... 1 answer · Top answer: Thanks for stopping by: This actually is DCER - you have a blown speaker. The radio is sensing ... Missing: E- ‎' Show results with: E-
Cd Player Unit - Kenwood KDC-138/138CR Service ...
ManualsLib https://www.manualslib.com > ... > Service manual Kenwood KDC-138/138CR Manual Online: components description, Electric Unit, Switch Unit, Cd Player Unit. Controls Fm/Am Tuner, The Changer, Cd Mechanism, ...
2/16/2024 6:44:56 PM • Kenwood Car... • Answered on Feb 16, 2024
How to power supply of kCSWA900 Kenwood sub whooper power supply 10 pin
Take a look at this manual diagram. https://www.manualslib.com/manual/359815/Kenwood-Ksc-Sw10.html?page=5#manual Given the above is not your model, at least it shows the 10 pin. Ironically, below I offer a diagram of your model. The irony comes in the fact that the diagram appears labeled in Japanese But if you compare the two diagrams, maybe something will make sense from the one with the English labels. Otherwise, you might fire off a query to Kenwood customer support. https://www.manualscenter.com/manuals/kenwood/kscsw900-owner-manual.html Here is a 10 pin harness compatible with the subwoofer. Kenwood Subwoofer Amp KSC Wa100 Wa80 Sw10 10 Pin Harness for sale online ' eBay I don't have any information on how to power supply a kCSWA900 Kenwood subwoofer. However, I can tell you that the Kenwood KSC-SW10 compact powered subwoofer has a built-in amplifier with a 38 watts RMS power and a wired remote for control over volume level, variable low-pass crossover (50-120 Hz), and selectable phase control (0°, 180°) . The subwoofer comes with a power/ground wiring harness and preamp (RCA) and speaker-level inputs .
1/26/2024 3:58:54 AM • Kenwood Car... • Answered on Jan 26, 2024
2answers
Kenwood DNX6160 Car Video Player Logo
17 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
installatoin manual kenwood dnx 6160
  • Car Audio & Video
