20 Most Recent Vizio VA370M 37 in. TV Questions & Answers
My tv picture is real skippy like a bad scratched
If its a new TV then bring it back,it is defective and if not then the TV is going bad.
10/24/2013 10:17:56 PM • Vizio VA370M 37... • Answered on Oct 24, 2013
Screen went black and no sound either?
This sounds like a very common issue.If set is hard to turn on (takes several tries)but will eventually turn on hereis what my guess would be.Every set has a standby power supplythat is running 7/24 if the set is plugged in and it supplies voltage to theremote circuit that turn on the main power supply for the tv and hence turn theset on.This is an area where companies cut corners by using lower rated voltage caps.By this I mean Standby usually provides under 10 volts to trigger the seton----what they do is use filter caps rated at say 10 volts max in a circuitwith 9 volts (example)=with the standby on all the time the filter caps(electrolytic caps) dry out and fail.The problem usually begins where you have to turn set on or or two times andgradually gets worse--takes longer and more tries to get it to come up.Once on it will stay on until turned off for a period of time.The caps will begin to work better (regain some of thecapacitance) as they get hot--hence one it is on it will seem ok.The beauty of this problem is most of themhappen when set is a year or two old (no warranty) and all you have to do islook at the top to locate bad ones.They are generally black or blue and round and vary in --they have twoconnections each--a + for positive and a - for negative--not unlike a batterywhich in a way they are. The + and - are marked on top and bottom of most boards.They are easy to replace and not expensive parts.The tops are silverand metal looking with creases on top and if bad they will be puffed up ontop---tops must be perfectly flat with no brown material leaking top or bottom.If this is your problem once you id them (make a drawing) you can begin.Here is the critical part---on each cap is also marked the value like 220uf 10vdc---220 micro farad at 10 volts maximum.If you find for example 6 puffed up and all are 10 vdc replace them with thesame value capacitance (like the 220 uf) but go up to at least in this case(from 10 volts) to a 16 or higher rated voltage cap.The only issue is when you go up in voltage rated value the cap is larger sosometimes there is an issue of physical space for the replacement on the boardto fit them in.The reason they cheapen these sets in this way is if 10 caps and you make25,000 sets there is a considerable savings in parts cost. They do not care as long as it lasts past the usual one year parts warranty.I have taken the time to be long winded because this really sounds like it maybe the problem you have.See attached photo of a typical cap and if you have questions or need advicelet me know.4_2_2012_2_04_33_pm.jpg
4/2/2012 2:04:46 PM • Vizio VA370M 37... • Answered on Apr 02, 2012
0answers
0answers
I have a Vizio VA370M
If the band is always there, looking the same, whatever the source of the image then the lcd panel is defective - this can't be fixed and a replacement panel will cost you as much as a new tv = just junk this one and get a new tv.
If the band is in the same position but its aspect changes then the fault is in the image processor and it, along with the mainboard on which it's soldered, must be replaced.
9/7/2010 3:05:06 PM • Vizio VA370M 37... • Answered on Sep 07, 2010
Will not power up, there was a power surge in the area when the tv quilt working
I would check the internal fuse first.
7/4/2016 3:57:00 AM • Vizio VA... • Answered on Jul 04, 2016
I need remote code to set upon Dish remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
5/28/2016 11:11:19 AM • Vizio VA... • Answered on May 28, 2016
What are the universal remote codes for this TV
5/27/2016 3:01:24 AM • Vizio VA... • Answered on May 27, 2016
My tv picture keeps going black
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
3/31/2016 7:36:07 AM • Vizio VA... • Answered on Mar 31, 2016
Lost my remote what other kind of remote can I use and I need codes and how to program the remote to work on my tv. I have several unversral remotes
go e-bay and there is a remote for vizio tv listed from the USA number 66700aba2-038-r a070305 selling for around $13.20 AUD ( US$9.99)--seller is cojacq ( 5669) contact www.vizio.com>about for a replacement unit direct from the manufacturer in Irvine Californic
3/31/2016 1:17:04 AM • Vizio VA... • Answered on Mar 31, 2016
Screen seems stretched. How do I fix it?
60'' Vizio TV screen is stretched in 'normal' screen mode on HD ...
https://answers.yahoo.com/question/index?qid...
Jul 21, 2013 - Ive had this tv for almost a year and the screen has never given me problems, but just recently all the HD channels are stretched. ... If your Vizio is like my 47" it has 4 Picture Modes - Wide, Normal, Zoom and Panoramic. ... Why isnt my viziotv able to play full screen hd channels?
TV Problem: The picture on my television is stretched out on the ...
Aug 23, 2008 - It is a High Definition Vizio TV. The center of the screen is clear, but the television stretches the image out on the sides. Is there anyway to fix ...
How to Fix the Most Annoying Features of Your New HDTV ...
1/1/2016 1:52:50 AM • Vizio VA... • Answered on Jan 01, 2016
Connect to internet
10/10/2015 7:50:38 PM • Vizio VA... • Answered on Oct 10, 2015
Vizio VA370M 37 in. TV Logo
24 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VA Vizio
  • VA Vizio
Most Popular Question
screen went black no sound either
  • Televison & Video
