20 Most Recent Dayton (3E406) Open Flame Gas MidSize Heater Questions & Answers
Pilot light went out and
the thermocouple is bad and will need to be replaced...
heatman101
4/21/2011 5:14:44 PM • Dayton (3E406)... • Answered on Apr 21, 2011
Dayton fuel trimmer 60000 btu. Everything lights and fan turns on but the flame isn't very big and the air isn't very hot. Warm maybe. What can I do to get more heat and a bigger flame?
I assume this is a typical heater, with an on/off thermostat rather than temperature-dependent flame size controller. Make sure the burner is clean and the flame holes are not clogged. Also make sure the heat exchanger is clean, not loaded with ash or dust. Verify that you have adequate air supply to the heater (if the flame gets much larger when you have doors open all the way to the outdoors, you definitely have a problem, including a safety issue) and that the exhaust stack is not blocked. I've seen issues caused by bird or wasp nests in the vent plumbing. Check inlet gas pressure, and verify that the heater main gas valve is functioning. (If you have recently added another gas appliance, the piping may not permit adequate gas flow when both are running.) If you have your gas piped in from a utility company, you may have to ask them to verify adequate flow and pressure at the meter. Check the inlet to the gas valve to make sure it is not clogged with sediment (requires shutting off gas and removing the inlet plumbing from the valve).
2/26/2024 5:55:09 PM • Dayton Heating &... • Answered on Feb 26, 2024
Dayton 2yu73 motors bad
Does not come on new motor won't heat up
1/19/2024 9:08:18 PM • Dayton Heating &... • Answered on Jan 19, 2024
How to manual reset the heater dayton 3vu37b
manual reset ? no manual reset use this site to download or read manual [troubleshooting ] ------- https://dayton.manymanuals.com/space-heaters
1/16/2024 2:48:52 PM • Dayton Heating &... • Answered on Jan 16, 2024
3answers
Is this motor reverable CW to CCW
according to specs it is. You will need to wire accordingly.
12/24/2023 10:35:37 PM • Dayton Heating &... • Answered on Dec 24, 2023
2answers
I have a Dayton Electric Motor Mod. 6K610E Is this a Single or Three Phase Motor
single phase 240VAC. data late will have info. 3 phase usually has 12 leads.
11/15/2023 10:01:00 PM • Dayton Heating &... • Answered on Nov 15, 2023
Where can I find the manual for Dayton wall heater 3e291 (1981)?
Obsolete,, no parts or manuals are available
10/4/2023 9:11:13 PM • Dayton Heating &... • Answered on Oct 04, 2023
What size orifice for a standing pilot in a 200,000 input Dayton heater converted to Liquid Propane Gas.
Help in the link, but you LPG Gas fitter should know all this. All gas installations must be done by a gas certified technician. https://www.google.com/search?q=Dayton+Furnace+3E847+LPG+Pilot+orifice+size ..
9/16/2023 12:03:10 AM • Dayton Heating &... • Answered on Sep 16, 2023
Dayton 1RKT5A Heater Wiring.
answer is unattainable since it is unknown what the previous owner has done to modify it ---you can try to get a wiring diagram [none on line ] and use a meter to check unit for modifications or a failed component -----or have a repair shop check unit
2/27/2023 1:27:02 PM • Dayton Heating &... • Answered on Feb 27, 2023
Need to know why my Dayton oil-fired portable heater starts runs for a few minutes and then acts like it's running out of fuel or starts puffing and shuts down and shuts down
limited info generic answer ---when last tune up --nozzle clogging--filter clogging --fire safety --high limit--fan sensor --dirty or failing ---vent
2/12/2023 3:53:32 AM • Dayton Heating &... • Answered on Feb 12, 2023
2answers
I need a circuit board for a dayton 210,000 torpedo heater 3VE52E
I'd give Grainger Supply a call
1/6/2023 9:05:12 PM • Dayton Heating &... • Answered on Jan 06, 2023
I got a Dayton 3e384a LP heater. The fan will come on, but it won't try to ignite the pilot.
check the igniter circuit--gas feed --thermocouple --fan-vent safety
12/13/2022 1:10:43 AM • Dayton Heating &... • Answered on Dec 13, 2022
2answers
Heater will show that power
This is probably a Tstat problem. Replace the Tstat and this will solve the problem.
11/21/2022 9:49:36 PM • Dayton Heating &... • Answered on Nov 21, 2022
I need a fan blade for motor A0416B2810
A serial number is no good in such questions as it is just a numerical sequence of the number made. In your case number 5. The model number will get the fan. https://www.google.com/search?q=Dayton+heater+fan The motor number also doesn't help because that motor spindle can take a radial fan or a bladed fan. https://www.google.com/search?q=fan+blade+for+motor+A0416B2810 Or you can contact Dayton direct
Garage Heaters ' Dayton Utility Area Heaters
http://www.daytonheatingandcooling.com > garage-hea... Garage heaters designed specifically for warming car ports and enclosed utility areas are our specialty. We have a variety of units to help keep non-living ..... ..
10/12/2022 6:09:45 PM • Dayton Heating &... • Answered on Oct 12, 2022
Dayton mid 3e368a won't shut off
Hi, Please remove the battery or disconnect the power source from the unit in order to shut the device off. Thank you.
10/7/2022 2:41:48 AM • Dayton Heating &... • Answered on Oct 07, 2022
I have a 3ev50 Dayton heater. It used to run with the cover off, but doesn't anymore. It's still sparking and trying to ignite but won't. What would be the most likely thing wrong with it? Thank you
Late to the show but might help others. Check for cracks in hoses. It sounds like a fuel draw issue. If ignitor is doing its job and, while motor is spinning, you don't see a mist of fuel coming out the nozzle then #1 hoses have cracks (1/4" I'd replacement hoses). #2. vanes on pump are not moving freely so pump pressure (about 5 pounds) is too low.
1/16/2022 3:53:01 PM • Dayton Heating &... • Answered on Jan 16, 2022
Dayton (3E406) Open Flame Gas MidSize Heater Logo
Popular Tags
1 questions posted
Top Dayton Heating & Cooling Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Dayton Heating & Cooling
Most Popular Question
pilot light went out
  • Heating & Cooling
