20 Most Recent
Samsung WB550 Digital Camera Questions & Answers
I can view my pics
Mine just started doing the exact same thing all of a sudden today! Have you found a solution for this yet?
My WB550 turns on then a lot of times will zoom by
1-Take the battery and the memory card out of the camera for few seconds. 2-Press and hold the power button for 10 Seconds 3-Insert the battery / batteries; please check the polarity direction. 4-Close the battery chamber cover. 5-Power on the camera again. If the same issue occurred so in that case the camera needs to be repaired
My mother dropped her camera
You definitely need to take it to a repair shop. The lens construction is too complicated. It is made up of too many small pieces of different materials.
Thanks for using fixya and goodluck on your digicam!
I was taking photos and evertime i took a photo i
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
My Samsung Es90 digital camera's shutter is not working, plus, the batteries are fully charged but when inserted, it only last 2-3 minutes. What can I do to resolve this?
I'm assuming by "shutter" you're referring to the one inside the camera and not the cover blades on the very front of the lens.
How old is the battery and do you use the camera a lot?
Old batteries can be fully charged but can become weak and not hold that charge when the camera is powered on. The shutter issue could be part of this as the battery might not be strong enough to power the shutter.
I think the batteries for these cameras are reasonably cheap so you could invest in a new one to see if that helps. An extra battery is always useful if you use the camera a lot.
If this is an old, well used camera part do wear out so if new battery doesn't help you may need to take it to a good repairer as the camera will need to be taken apart to find the problem.
