20 Most Recent
Cambridge Audio Sonata DV30 Player Questions & Answers
Unlock zones
Try some of these codes to see if the unlock the region:
Turn on the player
- Press OPEN/CLOSE
- Press ZOOM
- Press A/B
- Press Up, Left, Down, Right
A note should be displayed.
- Turn it off and on again
To set a particular country code:
- Press OPEN/CLOSE
- Press 1, 1, 1, 1
- Enter desired country code (1-6)
"Region X" (X=RC) is displayed now
Reset:
- Press OPEN/CLOSE
- Press ZOOM
or
- Open the disc tray
- Press 2, 9, 1, 8
- Press ENTER
- A menu shows up
- Press UP/DOWN to select "Region"
- Select RC (13=Codefree)
- Close the disc tray
or
- Press SETUP
- Go to the "Speaker Setup" page
- Press 9, 2, 1, 0
- Select "Support Mode On"
- Power the player off and on again
Generic problem for all DVD
These are the steps for a Cambridge Audio DV300, although I believe this model may be several years older than the Sonata:
- Turn your player on and open the CD tray.
- Press 2 9 1 8, then ENTER.
- Select 'Region'.
- Enter 13 for region free.
- Press EJECT.
If this does not apply to your model, there are half a dozen other Cambridge Audio DVD models
here & one of them may apply to yours' as well.
I hope that helps.
_______________________________________________
Cambridge Audio DV30 Manual
DownloadCambridge Audio DV30 Remote
Codes Download
Cambridge Audio Azur 640A V2.0 not reacting to remote control
If your Cambridge Audio Azur 640A V2.0 amplifier is not responding to the volume buttons on the remote control, there could be a few possible causes. Here are a few things you can try:
- Check the batteries: Make sure that the batteries in the remote control are fresh and inserted correctly.
- Check the remote sensor: Make sure that the remote sensor on the amplifier is not blocked or covered by anything. Also, ensure that the remote sensor is pointing towards the remote control.
- Check the remote control functions: Make sure that the remote control is in the correct mode, and that you are pressing the correct buttons for the volume control.
- Check the connection: Make sure all the connections between the amplifier and other components are secure and tight.
- Check the potentiometer: The potentiometer (also known as the volume control) is the component responsible for controlling the volume of the amplifier. If the potentiometer is not functioning properly, then the amplifier will not respond to the volume buttons on the remote control.
- Contact Cambridge Audio: If you have tried all of the above steps and are still unable to get the remote control to work, contact Cambridge Audio technical support for further assistance. They will be able to provide you with additional troubleshooting steps or advice, or they may need to send a technician to repair or replace the amplifier
When i play a dvd i get sound but no picture.
Check your cabling. I'm willing to bet that a wire is crossed on the back your system.I've been known to accidentally swap the white and yellow components behind a TV a couple times.
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
