20 Most Recent
Cambridge Audio Azur 650BD Player Questions & Answers
Slow loading
It must be the problem with your internet connection or with your service provider. Sometimes your internet speed drops because of the maximum number of users using bandwidth on single back end providers IP, which is shared for all users. For that there are some points that can help you attain your loading speed:- Refresh your internet connection- Shutdown your router for minimum 10 minutes so that your back end IP can be change by service provider- Remove your Temporary files from your system- Try to use Reginout for constantly refreshing internet connections
Cambridge Audio Azur 640A V2.0 not reacting to remote control
If your Cambridge Audio Azur 640A V2.0 amplifier is not responding to the volume buttons on the remote control, there could be a few possible causes. Here are a few things you can try:
- Check the batteries: Make sure that the batteries in the remote control are fresh and inserted correctly.
- Check the remote sensor: Make sure that the remote sensor on the amplifier is not blocked or covered by anything. Also, ensure that the remote sensor is pointing towards the remote control.
- Check the remote control functions: Make sure that the remote control is in the correct mode, and that you are pressing the correct buttons for the volume control.
- Check the connection: Make sure all the connections between the amplifier and other components are secure and tight.
- Check the potentiometer: The potentiometer (also known as the volume control) is the component responsible for controlling the volume of the amplifier. If the potentiometer is not functioning properly, then the amplifier will not respond to the volume buttons on the remote control.
- Contact Cambridge Audio: If you have tried all of the above steps and are still unable to get the remote control to work, contact Cambridge Audio technical support for further assistance. They will be able to provide you with additional troubleshooting steps or advice, or they may need to send a technician to repair or replace the amplifier
When i play a dvd i get sound but no picture.
Check your cabling. I'm willing to bet that a wire is crossed on the back your system.I've been known to accidentally swap the white and yellow components behind a TV a couple times.
I Have Lost My Remote To My Studio Standard RS-912
If you have switched off it by using power button to its remote control, you must have its remote control to switch it back on. Anyway, try pressing the Ch up or Vol up buttons once. In rare cases, this might make it switch back on.
