20 Most Recent JCPenney Armitron Men's Steel Blue Dial Watch Questions & Answers
0answers
Need instructions on how set watch armitron
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file
2/21/2010 9:28:04 AM • JCPenney... • Answered on Feb 21, 2010
How to set date and day
Go to the Armitron web site "armitron.com" and select "support" from the menu across the top. Scroll down the watches illustrated and choose the one that is similar to the one you have and download the instructions.
1/21/2010 3:34:55 PM • JCPenney... • Answered on Jan 21, 2010
DECADE WATCH HAS NO SETTINGS MANUAL
If your Decade watch is like mine it has 4 push buttons (10, 2, 4 and 8 "o'clock" positions respectively; and one pull and turn stem (at 3 o'clock position) -
For the purpose of setting the watch and functions mentally label the push buttons as follows:
10 o'clock position "A"
8 o'clock position "B"
2 o'clock position "C"
4 o'clock position "D"
NORMAL TIME SETTING
1) In normal time readout press B (3x) to get to normal time setting mode: "SEC" will start flashing, press C for synchronization
2) Press D once: "MIN" will be flashing, press C to advance
3) Press D once: "HOUR" will be flashing, press C to advance ("A" is for am, "P" is for pm, "H" is for 24 Hour format)
4) Press D once: "DATE" should be flashing, press C to advance
5) Press D once: "MONTH" should be flashing, press C to advance
6) Press D once: "DAY OF WEEK" should be flashing, press C to advance
7) Press B once: Setting is completed, return to normal time readout
ALARM TIMES SETTING
1) In normal time readout press B (2x): Alarm time "HOUR" should be flashing, press C to advance
2) Press D once: Alarm time "MIN" should be flashing, press C to advance
3) Press B once: Setting is completed, return to normal time readout
ALARM FUNCTION
1) In normal time readout press C and D simultaneously: Alarm signal should appear
2) In normal time readout disarm alarm by pressing C and D simultaneously: alarm signal should disappear
Note: Alarm (when activated) will stop itself after 1 minute; or can be silenced by pressing D or press C to snooze for 5 minutes (operates for 1 hour)
CHIME
1) In normal time readout press D and B simultaneously: Chime signal should appear
2) In normal time readout disarm chime by pressing C and D simultaneously: alarm signal should disappear
CHRONOGRAPH (STOP WATCH FUNCTION)
1) In normal time readout press B once to get into "CHRONO" mode: press C for to start counting event -
While in Chrono mode there are two options
a) During a counting event: press C to stop counting, press D to clear and reset stopwatch to 0:00
b) During a counting event: press D to see a "split" time (IE first leg of a relay time is shown while the counting event continues, press D again to return to running counting event; press C at end of event, press D to reset stopwatch to 0:00
2) press B to return to normal time mode
5/31/2009 7:42:43 PM • JCPenney Watches • Answered on May 31, 2009
Sector adv 1000 manual
ZERO-SETTING OF THE SECONDS-HAND & SUB-SECOND HAND ON THE SECTOR ADV1000 CHRONOGRAPH. NOTE: The pusher buttons A, B & C are positioned on the watch at the 2 o'clock (A), 10 o'clock (B) & 8 o'clock positions (C), while the crown is at the 4 o'clock position. 1) Set the crown at the normal (in) position. 2) Push the B button twice. 3) Pull out the crown to the 2nd position (fully out). a.) Seconds-hand setting: a push of button A moves the 2nd hand by 1 second. Move it until it is at the zero position. b.) 2/100ths second hand: a push of button B moves the 2/100ths second hand by one 2/100ths second. A continuous push moves it quickly. Move it until it is at the zero position. 4) Push the crown back in to normal position. QUICK-SET OF THE CALENDAR DATE With the alarm switch off, pull out the crown halfway to the first "out" position (not fully out). Turn the crown clockwise to quick-set the date. sector adv1000 zero-setting & date instructions-undefined-undefined-0.jpg
4/25/2024 5:30:35 PM • Watches • Answered 12 hours ago
I'de like to have a
Si porque tengo este reloj
4/17/2024 7:04:45 AM • Watches • Answered on Apr 17, 2024
2answers
How do i take my george watch out of 24 hour time?
how do you set the time on the digital george watches?
4/11/2024 7:38:43 AM • Watches • Answered on Apr 11, 2024
My pearl necklace has broken
Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
Thank you for contacting FixYa.
Jewel
4/7/2024 2:26:15 AM • Watches • Answered on Apr 07, 2024
BASE, METAL BEZEL STAINLESS STEEL BACK 10/4312-13 75311 THAILAND MOVT WATER RESISTANT 100F1 QUARTZ
Question edited for clarity. Please don't type in all CAPS, it is considered SHOUTING and is harder to read especially in a jumble of words and numbers. 377, although a maker would be useful! https://www.google.com/search?q=battery+METAL+BEZEL+STAINLESS+STEEL+BACK+10%2F4312-13+75311+THAILAND+MOVT ..
4/6/2024 1:45:42 AM • Watches • Answered on Apr 06, 2024
2answers
U.S. Polo Assn. Sport Men's US9061 Black Rubber Strap Watch. I need the INSTRUCTION MANUAL FOR bc534-1741el please.
No manual, just this. You can however just search by the number of buttons, 2 , 4 or 4. They are all the same. Google 4 button chronograph watch manual
4/5/2024 10:45:51 PM • Watches • Answered on Apr 05, 2024
Would like to check serial number on ferrari watch
yes
4/3/2024 8:07:40 AM • Watches • Answered on Apr 03, 2024
CANDINO WATCH 10965 PLAQUE G 10 WF. Is it made of gold please.
Question edited for clarity. Please don't type in all CAPS it is considered SHOUTING. No, they are gold plated. https://www.google.com/search?q=CANDINO+WATCH+10965 ..
3/22/2024 2:45:09 AM • Watches • Answered on Mar 22, 2024
JCPenney Armitron Men's Steel Blue Dial Watch Logo
7 questions posted
Top JCPenney Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a JCPenney Watch Expert? Answer questions, earn points and help others
View Most Popular
JCPenney Watches
  • JCPenney Watches
Most Popular Question
need instructions set watch armitron
  • Watches
