20 Most Recent
JVC 42 in. LCD TV Questions & Answers
42e488
Most hardware stores carry these mount screws. They are standard sizes ranging from M3 to M8 or so and from 15 mm to 25 mm. Try Amazon if you can't find them, an assortment shouldn't cost more than a few bucks.
Free manual lt-40a320
Need manual to find out how to get rid of the PIP and get the 40" main screen. What's in the PIP is in fact the regular 40" screen image. I am trying to restore the regular 40" back. I thought maybe the manual would be a big help. Thanks to any suggestions.
My flat screen tv wont turn on...what does that mean?
most likely your set has an internal failure and will need to be serviced. You can try unplugging it for a while, then plugging it back in to see if it will power up. But it is possible that you have a failure on your power supply board or the main board.
Sound but no picture
Show a flashlight on the screen from a safe distance. If you can see the picture, the backlights are off. The TV needs servicing.
Yellow lines on jvc lcd tv
tried to re seat first the cable at the t-con board that transfer signal on the screen panel display which may have loose contact on the connector.
JVC TV WONT KEEP IMAGES ON
Change input device to some other like a DVD player and see.Switch off TV, switch off power, remove plug and wait for 48 hours and retry.If problem persists, call in a qualified service technician.
NEED BOLT SIZE TO MOUNT 42 JVC LCD 120HZ PLEASE
Best way is to Call JVC customer service with the model number--need number of bolts,thread type and you are going to find in almost all cases they are standard ones---Home Depot will have them.
