20 Most Recent Bosch KGU31124 Bottom Freezer Refrigerator Questions & Answers
Water keeps on collecting at
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
9/19/2011 2:49:12 AM • Bosch KGU31124... • Answered on Sep 19, 2011
Bosch KGU31124 Freezer Not Working
I have the same freezer and get the same problems. Ice forms on the refrigeration fins beind the plastic shroud at the rear and completely blocks the airflow. The fan that moves cool air around does not work then and freezer temp goes up. Ice will often push the shroud forwards so that the door does not close properly. Warm moist air get in and just increases the ice problem.
I take the shroud and fan housing off the rear (4 screws and a wire to the fan) and defrost thoroughly using a hair dryer. You can then see when all the ice has gone..
5/23/2011 8:51:40 AM • Bosch KGU31124... • Answered on May 23, 2011
B36CL80SNS in Demo Mode - Help Troubleshooting?
To Exit Demo Mode: Hold down the Start/Reset button for 3 seconds. The display will show: 0:01 2. Press the button and the Delay Start button at the same time.
1/8/2024 4:42:45 PM • Bosch... • Answered on Jan 08, 2024
Bosch Series 2 KGN34NWEAG Fridge Freezer. The alarm sounding/not cooling in fridge compartment.
Call them out under warranty. the circulation fan is normally at the back of the fridge. On such a new fridge, so shouldn't need to be fixing issues. A fan is an 'electrical component', not an electronic item. https://www.google.com/search?q=Bosch+Series+2+KGN34NWEAG+Fridge+Freezer+warranty Refrigerators
  • Limited warranty, entire appliance, parts and labor (1 year).
  • Limited warranty for non-electronic components; parts only (1st to 2nd year).
  • Limited warranty for electronic components; parts only (2nd to 5th year).
  • Limited warranty for rust-through on stainless steel; parts only (lifetime).
10/3/2023 6:56:21 PM • Bosch... • Answered on Oct 03, 2023
How to access light bulbs on a Bosch KGU6655/07 fridge freezer please.
This page of the manual refers https://www.manuals.ca/bosch/kgu6655/manual?p=29 And I found this There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the third tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
7/15/2023 3:00:07 PM • Bosch... • Answered on Jul 15, 2023
My Bosch KAN58A70 side by side fridge operation intermittent. Fan and compressor off with unit on.
Make sure condenser coils are clean they can be readily accessed from behind or under the unit, you should clean them every 6-12 months.
7/1/2023 5:41:45 PM • Bosch... • Answered on Jul 01, 2023
Bosch B26FT50SNS fridge. How to repair broken wire in left ice/water door?
To repair a broken wire in the left ice/water door of the Bosch B26FT50SNS fridge, it is possible to disassemble the left door water/ice dispenser. However, it is important to note that this process can be complicated and should only be attempted by someone with experience in appliance repair. To begin, unplug the fridge from the power source and remove any items from the door shelves. Locate the screws that hold the dispenser cover in place and remove them using a screwdriver. Carefully pry off the cover and set it aside. Next, locate the wire that needs to be repaired and determine where it is broken. Cut away any damaged sections of wire and strip the ends of the remaining wires. Twist together the ends of the wire that was cut and use electrical tape or wire nuts to secure them together. Reassemble the dispenser cover by aligning it with the door and pressing it into place. Replace the screws that hold it in place and tighten them securely. Finally, plug the fridge back in and test the ice/water dispenser to ensure that it is working properly. In summary, to repair a broken wire in the left ice/water door of a Bosch B26FT50SNS fridge, you can disassemble the left door water/ice dispenser, locate and repair the broken wire, and reassemble the dispenser cover.
6/21/2023 8:42:28 PM • Bosch... • Answered on Jun 21, 2023
Should I repair or just replace my Liebherr fridge/freezer
Looks like this model is now out of date and I wouldn't trust your service guy. Any service agent will know whether the door switch, thermal sensor or control panel is faulty by simply testing them. I would not have to fit complete parts to isolate the faulty part. Sounds like he doesn't know how to or wants the job of fixing it. Try an independant repair service, local one man repair shops tend to give an excellent service. If you want Currys do a good range of fridge freezers; https://www.currys.co.uk/search?q=Liebherr+fridge-freezer+model+CPEL4813&search-button=&lang=en_GB https://www.currys.co.uk/appliances/refrigeration/fridge-freezers/bosch?searchTerm=Bosch%20fridge%20freezer https://www.currys.co.uk/appliances/refrigeration/fridge-freezers/hoover?searchTerm=hoover%20fridge%20freezer To show just one retailer. There are many more out there. Try and buy locally if you can, you will get a better service I find. I bought a Philips (Whirlpool) years ago and after 3 years, out of warranty, it packed up. The aluminium heat exchanger started leaking. Not worth repairing. I now purchase Hoover. They has a 10 year parts warranty. They are all 15 tears old now. One gets what one pays for I suppose.
5/17/2023 7:54:26 AM • Bosch... • Answered on May 17, 2023
2answers
KGV28V01GB/21 light at half bright when door shut?
  1. Check the door switch: The door switch is responsible for turning the light on and off when you open and close the door. Disconnecting the switch, as you have already done, can confirm if the switch is working correctly or not. If it still remains at half brightness, the switch may need to be replaced.
  2. Check the light circuit: If the switch appears to be working correctly, there may be a problem with the light circuit. This could be a problem with the wiring or the bulb itself. You can try replacing the bulb to see if that resolves the issue.
  3. Contact Bosch Support: If the problem persists,
2/14/2023 1:13:53 PM • Bosch... • Answered on Feb 14, 2023
Screwdriver needed to remove screws on back of Bosch Fridge/Freezer
Star 5 Point Torx are available at Walmart amazon home dept
2/5/2023 2:04:48 AM • Bosch... • Answered on Feb 05, 2023
How to get replacement drawers for my Bosch intelligent freezer 32
order them bosch--appliance repair shop --online search
2/1/2023 1:17:06 PM • Bosch... • Answered on Feb 01, 2023
Hi, I need new drawers for my Bosch stand alone freezer. Intelligent freezer 32. They have all broken. Can I order new drawers. 6 of them.
fixya doesnt sell products try manufacturer go to an appliance shop or online search using make and model
1/31/2023 6:50:34 PM • Bosch... • Answered on Jan 31, 2023
For our Bosch Model-B20CS80SNS/02 Refrigerator - Water is not Dispensing
Maybe check the water line.
1/27/2023 2:42:57 PM • Bosch... • Answered on Jan 27, 2023
Bosch KGU31124 Bottom Freezer Refrigerator Logo
7 questions posted
Top Bosch Refrigerators Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Bosch Refrigerators
  • Bosch Refrigerators
Most Popular Question
water keeps collecting
  • Refrigerators
